Motor mounts: poly or rubber?
Posted by phlat65
Re: Motor mounts: poly or rubber?
September 14, 2011 08:05PM
sidewaez
OH well that's why we should "quote' the reply youse are talking abouts...
That's pretty good, got some details ya wanna share?
Like part numbers etc just to be sure?
they are the:
KLARIUS/QUINTON HAZELL Part # EMS1554
Category: Control Arm Bushing
from rockauto
and it works out to be $11 each shipped if I get 8
or
$9 each if I buy 16
I don't know anyone in the UK to mail them to but going postal would save quite a bit
What diameter tubing do these fit into John?
Sean has half a dozen brothers there and is sending me a postal adress, hang tight so this works, I can measure the OD and letcha knows so we don't go Oh Noez!
September 14, 2011 09:57PM
Messages have been sent, we will see if any of by brothers check e-mail.....
September 15, 2011 12:04AM
We all say Ta, smate!
September 15, 2011 09:31AM
John, I PM'd you his address.
September 15, 2011 10:03AM
Thank you
September 15, 2011 12:31PM
Remember, small parts only! I don't want to get a call about some engine or body shell showing up on his door step.....
sidewaez
Blake Lind
orange AE86
September 16, 2011 07:01PM
are you going to get enough of these for everyone?
I need 6...
September 16, 2011 08:35PM
Here is what I am going to use Blake and John.
Raybestos PN 576-3358
1994 Ford F250 front leaf spring bushing.
The outer shell is 2.004" which should press into standard 2" ID tube, available in both steel, 4130, and Aluminum
3.125" overall length. They could easily be cut down to whatever length you wanted, I think I will use them at the stock width.
14mm bolt hole, a little big, but bigger is better than too small.
$11 each, in stock at Carquest
September 16, 2011 09:53PM
Looks awr-fully good, Sean. If we pressed in some 1mm wall sleeves we could save buying bolts--and use 2.3 head bolts, we'ze gotz plenty to go around.
September 16, 2011 10:01PM
I have stacks of bolts that will work, we change some MB control arm bolts out for an adjustable bolt, and they are perfect. But you are right, a simple sleeve and 12mm bolts would be better
Whats the ID on those nice Aluminum slugs you have in that tub John?
September 16, 2011 10:05PM
I stink they're about+- 47~~48mm
I can check the OD if they can be bored to 2" ID
sidewaez
Blake Lind
orange AE86
September 20, 2011 01:28AM
looks good! nice work! I'll check tomorrow but I might have a lot of 2" i.d. aluminum tubing at work.
sidewaez
Blake Lind
orange AE86
September 20, 2011 04:23PM
the tubing I've got is 1 5/8" i.d...
September 20, 2011 06:06PM
Online metals lists 2" in alloy, dom, and 4130, $20 for enough to do 4 bush holders.
sidewaez
Blake Lind
orange AE86
September 21, 2011 04:14PM
what wall thickness were you thinking, .250" ?
