Motor mounts: poly or rubber?
Posted by phlat65
Re: Motor mounts: poly or rubber?
September 21, 2011 05:17PM
Probably .120 steel, .250 alloy
November 02, 2011 01:02AM
They are almost done. Just final welding left to do. Came out super Bitchin if you ask me.
MrToad
Jim Turner
none, gopher
November 02, 2011 07:51AM
Hard to tell from the photos but it looks like the reinforcing gussets will prevent the outboard/bushing side of the mounts
from coming out vertically. Does this mean you detach the inboard/motor block side when you want to pull the engine?
JT
November 02, 2011 09:39AM
Yep. Without those little triangles, it was a very likely place for cracking to occur. I did not do this mod for ease of engine change, so it does not bother me.
November 02, 2011 10:21AM
Or slide it back and forth and lift one side at a time possibly.
November 02, 2011 10:23AM
In other words, sometimes we decide to divert from an already proven design and then we have to add things to avoid one problem and create another.
tongue sticking out smiley
November 02, 2011 10:41AM
Looks hellaflush, yo.
Be IN with the in crowd.
November 02, 2011 11:09AM
Yeah well you'll have a Volvoised version of that before next rally so you can be In with the In crowd.
You can be singin it!
<object width="420" height="315"><param name="movie" value="
?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"><
Mad Matt F
Matt Follett
November 02, 2011 05:57PM
Oh my....
dose rR purrrrty!
November 03, 2011 12:08AM
Welded them up tonight. I have been having issues getting quality welds lately, took out the cheap wire I bought somewhere, and put in a fresh roll of quality wire from the welding supply. What a difference that made. No more budget wire for me.
