Interior pictures/ideas
Posted by BobOfTheFuture
Re: Interior pictures/ideas
March 16, 2012 09:28PM
is that a twist throttle under the wheel?confused smiley
That's right. Jari is a paraplegic. He uses a hand throttle that also connects to the brake pedal. He won production class at 100AW, and put a lot of other drivers, both 2WD and AWD to shame.
PotatoFlakeSTi
Joachim Sandgaard
1990 Eagle Talon TSi AWD
March 16, 2012 10:04PM
Put a smile on my face, good for him!
March 17, 2012 12:16AM
Pat, stock heater box works great in the XR. It is pretty light. I do like to be able to switch from defrost to cold air out the dash vents, really helped at Idaho.
Max
1983 MKI GTI
March 19, 2012 04:39PM
that is awesome, even above the crowd surfing wheelchair i saw at Godsmack.
BobOfTheFuture
Rob
None, anymore.
March 20, 2012 08:24AM
Jari, I too was not aware. You're awesome.
I have a different queestion to add to all this as well:
Do you guys use any of the stock body harness? Or rewire the whole car yourselves?
Ive been just pairing down the stock harness, and once I am healthy, I am going to attack the jungle behind the dash area and try to get the fuses in a central position. Ill have to cut into 2 or 3 bundles that are 3 inches thick, and I am worried its just going to turn into a quagmire. I am not sure yet what angle to take on this...
Enablers, All of you.
bttmotorsport
Jari Hamalainen
Opel Monza, Chevy Monza to be finished 2012, BMW 318 iS
March 20, 2012 09:02AM
BobOfTheFuture
In BMW i used mainly the stock harness, stereo, airbag etc removed, as said, many times it helps a lot when you can find scheme of the harness if it happens that you need to locate the electric fault..
For extralights,fan etc i used Hella relays which have fuse attached, easy solution...
Many times if you start wiring the car yourself (not always), the outcome is heavier than original, same goes with dash, i´d guess the e36 dash weighs apprx 5lbs airbag removed...
open | download - IMG_0505.JPG (90.9 KB)
