Anyone else ran a locker in a rwd rally car?
Posted by mellow65
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
Re: Anyone else ran a locker in a rwd rally car?
May 21, 2017 11:57PM
Oh yeah I know you can break rwd axles-I've done some of that myself(dana44).
And yes assuming you actually let off the gas every once in a while so it can unlock-a detroit style locker is going to be easier on your axle shafts than a spool.
So I CAN see how it helped with the Volvo breaking axles.
My question I guess is more -is the dana 30 sufficient for that specific rally car in the first place?
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
May 22, 2017 06:02AM
Kind of interesting. I come from an RX-7 background. There were two main flavors of RX-7 rearend, the "small bearing/axle" 24 spline units and 26 spline "big bearing/axle". Spline pitch is roughly the same as common American units so you can roughly correlate axle size to Dana/GM/Ford units.
Australian guys making "big" power in the 90s (500-600hp at flywheel) with cheap Japanese junkyard turbo engines found that the big axle rears were actually weaker than the small axle ones, since the small axle rears had stiffer housings, while the big axle rear had thinner material to save weight. The axles themselves may have been stronger but when the housing bows and flexes under load, the axle would be forced to bow and flex too and then it'd break.
And what did Ford and just about everyone else rallying in the 70s do with their solid axles.... big fat beefy trusses and braces and diff covers assemblies that extended out practically to the hubs. And full floating housing ends so that the axle was just an axle, making not just the wheel support stronger since it now had two bearings, but the axle could also have more leeway to flop around in its splines WHEN things shifted.
Interesting that I broke my first axle at the same event that I broke one of my rearend braces off. Coincidence or nail in the coffin?
Anyway, I'm thinkin', how strong is the Dana 30 housing, and is there a good brace/truss setup available if it could stand for improvement?
Edited 1 time(s). Last edit at 05/22/2017 06:03AM by Pete.
Robert Culbertson
Out of this dumpster fire
May 22, 2017 09:03PM
RALLYRS
Most definitely. Bracing the axle is definitely a good idea. Bracing it would not be a big issue either. The axle breaking is usually just an issue when the diff is welded. There are people making 780+whp/700+lb-ft and and running it through a stock diff. The v8 powered "drift" volvo I have has never broken an axle in 2 years. But, I run really crappy tires on it and never turn it sharp on asphalt unless the rear tires are smoking smiling smiley
May 22, 2017 10:21PM
my Toyota axle is both not braced and running the Weir kit. Booya.
May 23, 2017 12:19PM
So the next thing would be for you to actually drive it? Say, at Mendocino? spinning smiley sticking its tongue out
May 23, 2017 02:52PM
And, how's your mazdog coming along, sir?
May 23, 2017 03:38PM
Mine? Found a new shell for it, all straight, rust around the the windows, some small floorpan holes, no other damage. Won't get to pick it up until the end of July, when the current owner finishes stripping all the stuff he wants from it. That's fine as it should give me enough time to finish unpacking the garage.
