WRCWRXSTI
John Turner MacCallum
1988 Mazda 323 GTX
Mazda 323 GTX Center Differential Lock Button
September 24, 2011 12:56PM
the center differential wont unlock itself when i hit the button. the button just depresses, but the light stays on and the differential stays locked. Anyone have any experience with this?
Re: Mazda 323 GTX Center Differential Lock Button
September 24, 2011 01:00PM
Try reversing a few feet, pulling forward a few feet, and repeating for a bit. Alternatively, try finding a spot with a good bump in the road and just drive over it at 10mph, sometimes that little jiggle on the driveline is enough to let it come undone.
As the cars get older, the mechanism in the t-case starts to stick. You may need to dig into the underside of the car to get it fixed, but in my experience you may be OK doing the forward reverse thing for a bit.
Don't drive in tight arcs with it locked, you can break stuff from the binding.
Only lock it when you're going to rally on loose surfaces.
September 24, 2011 01:37PM
Or,
put a piece of tape over the light.
Edited 1 time(s). Last edit at 09/24/2011 01:37PM by john vanlandingham.
September 24, 2011 03:21PM
While I'm all about that for a fix to a check engine light, driving around a GTX with the diff locked is a recipe for certain diff failure.
If it won't turn off in short order, there is a way to manually do it...but I don't remember how to do it.
September 24, 2011 04:54PM
Well would turning the radio up real loud help with that?
Is there an external lever or stumpy thing to turn or is that sumpin other Japonaise box?
September 24, 2011 06:15PM
You have to take the diff lock motor off the transfer case and actuate it manually. It's a pull or push with a 90deg rotation but I've never done it myself. You can look it up on the Yahoo archive. I do know where the motor is located so good luck if your hands aren't girlish and tiny grinning smiley
WRCWRXSTI
1988 Mazda 323 GTX
September 24, 2011 09:39PM
well its a good thing they are then
Edited 1 time(s). Last edit at 09/24/2011 09:40PM by WRCWRXSTI.
Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
September 25, 2011 09:50PM
The most common failure mode of the difflock moptor is that the motor magnets, being glued to the inside of the housing with what appears to be Elmer's, simply fall off one fine day and that's that. Once you get the damn motor off the trans and apart, it's an easy fix, what with the cleaning off of the housing and magnest and the liberal application of Devcon. In any case, ya wanna run that centerdiff unlocked or the poor thing will die a horrible death.
Sometimes it's an easier fix than that, just a fuse, but since you have a light at the switch, that ain't it. Check continuity 'tween the switch and the motor, in case it's a chafed wire. but I'm gonna guess unglued motor magnets.
I have a nice clean gone through difflock motor in my shed for sale in case you're wanting a spare---and some millen panasports and maybe some doors and a rear hatch and who knows whatall else....
WRCWRXSTI
1988 Mazda 323 GTX
October 01, 2011 02:05PM
i tried driving forward and reversing for quite a while, as well as driving over several bumps at varying speeds, but still no luck. so this mechanism is located in the transmission case? any tips on finding this thing and unlocking it manually?
WRCWRXSTI
1988 Mazda 323 GTX
October 01, 2011 02:25PM
oh i gotta seperate the motor from the transmission...
Jay
Jay Woodward
Jay
October 01, 2011 11:25PM
no ya don't! you need to locate the difflock motor on the backside of the trans, sorta under the intake manifold. There are I think 3 std bolts, and one special bolt that you have to turn halfway to get the shaft to unlock. It's fairly obvious which bolt that is, and I could tell you, if i had a functioning memory. but once you get that far, you can pull the shaft by hand, button it up, and forget about it if you want. no need to separate engine and go through all that rot.
October 02, 2011 12:40AM
WRCWRXSTI
No. You need to get a BOOK.
You cannot own a car and rely on intra-webs forums to after days and days give you ideas that you could know the correct answer to in 2 minutes..
Book
<iframe width="420" height="315" src="http://www.youtube.com/embed/wlsQIEIEeKA"; frameborder="0" allowfullscreen></iframe>
<object width="420" height="315"><param name="movie" value="
?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param>
WRCWRXSTI
1988 Mazda 323 GTX
October 08, 2011 03:05AM
damnit! i had it unlocked for such a long time and then i accidentally hit it again while trying to put a cigarette into the cig tray... looks like ill have to just buy the damn manual and find that diff lock motor.
October 10, 2011 12:09PM
Technically you are required to have the book to rally anyway it is in the rules somewhere that a shop manual must be presented at tech if requested. (I think for all classes but it might only be PGT and P) It is a good book by the way.
Mine would take a long time to unlock.
SgtRauksauff
Jorden
October 16, 2011 04:24PM
once you get it unlocked, disconnect the switch.... smiling smiley
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
