hand brake options?
Posted by puckhead
puckhead
Ken Lewis
96 coupe 2.5 swaped and stripped waiting for a cage
Re: hand brake options?
October 21, 2011 11:00AM
well I decided to go ahead and do it I am going to try to find a master I was thinking about using a clutch master any idea on what bore size to use? I assume I will have to buy a couple of residual check valves to put in the lines to the front brakes?
October 21, 2011 01:42PM
Just buy a willwood master, they are only $50 or so. No need for check valves if plumbed properly.
Size depends on handle length, handle ratio, ect.
Robert Culbertson
Out of this dumpster fire
October 21, 2011 01:51PM
I'm confused on how running a stand alone master with it's own reservoir won't require some special plumbing/check valves, unless you were running a second set of calipers (did I miss that?). It seems to me that as soon as brake pressure is applied from the pedal, the fluid would be forced up into the reservoir and overflow it. Am I missing something here?
The CNC inline brake makes perfect sense to me, and it works in my car. It was cheap in the grand scheme of things and did I mention that it works?
October 21, 2011 02:32PM
Robert Culbertson
You plumb the master cylinder in line, not parallel. So the line coming from the foot brakes goes on the feed port for the handbrake master. No need to use a dedicated reservoir for the handbrake.
Edited 1 time(s). Last edit at 10/21/2011 02:33PM by Cosworth.
Robert Culbertson
October 21, 2011 04:14PM
So basically the exact same setup that CNC uses, got it. When I was thinking master cylinder, I kept on think w/ external reservoirs.
puckhead
Ken Lewis
October 21, 2011 06:49PM
so what keeps the fronts from being applied I assume the roos are diagonaly split brake sys?
October 21, 2011 06:52PM
Yes, no diagonally split systems. Line from foot master to hand brake master in, hand brake master out to "T" fitting, to each rear brake whatever.
REDrum
Niall Johnson
02 WRX AKA "The Dragon"
October 29, 2011 04:07PM
for the dozen times a year I need to lock up the rear wheels I use a reverse action OEM handbrake. Pull up no ratchet and rear shoes are engaged, hold button to lock it up. I think it was done by VT-car. AKA the drfter special
October 30, 2011 01:35AM
so why does the smaller diameter resiouver work so much better?
October 30, 2011 11:21AM
so why does the smaller diameter reservoir work so much better?
Que?
Youse means small diameter cylinder ID?
Whatchyoo talkin bout?
October 30, 2011 06:27PM
Simple hydraulics man. Smaller cylinder has to move more do displace the same fluid, more movement for the same work performed = more mechanical advantage.
October 31, 2011 12:35AM
Que?
yea i meant diameter. My brain is off.
October 31, 2011 12:57AM
Que?
ratios mang, ratios. say it's 1 cm2 at the master. and say brake caliper is 10 cm2, you yank lever with 10kg force on that 1 cm.
Youse gots 10kg/cm2 at the caliper, but youse gotz 10x 1cm2 EACH with 10kg.
ratios of master cm@2 to caliper cm2.
We are trying to LOCK the wheels with reasonable arm effort afterall you we want a big hydraulic ratio, and a "OK" mechanical advantage.
Claro, muchachito?
October 31, 2011 01:23AM
makes sense.
