puckhead
Ken Lewis
96 coupe 2.5 swaped and stripped waiting for a cage
hand brake options?
September 25, 2011 12:57AM
So its getting close I am just wondering what my options are as far as hand brakes go or should I even worry about a hydraulic one yet?
Re: hand brake options?
September 25, 2011 12:30PM
There are a lot or people with a lot of reasons to defend installing a hydraulic handbrake. I think you're better of learning to drive without having a handbrake as a crutch. (Most people admit that it is a last resort that comes into play when things aren't working right.)
If your plans for the car involve re-routing the brake lines anyway, then I'll admit this is not a TON of extra work, but it is still extra work for minimal returns. If you're changing rear brakes to something without provision for cable handbrake - the question answers itself.
If you are building something AWD with a tight and fixed rate centre diff (25kg STi par example) a handbrake will disappoint you. (It works on all 4, not just the rears)
September 25, 2011 09:23PM
CNC staging brake. $130 or so, integrated master and mount.
You can also modify the stock handle to actuate a master. $50 master and some fittings.
September 26, 2011 09:53AM
master $15 then the handy work I would recommend buying one if
you like avoiding head aches.
simoniac
Simon Wright
Rally Spec Focus
October 07, 2011 05:31PM
I went low tech. For the few turns when LFB doesn't quite give me the rotation I need, this does the job quite nicely. No finesse - I just need to stop the rear wheels from spinning so they break loose.
Steel bar from Lowes, that I bent bent to shape then parallel matched with another piece. Welding by Anders(TM). Handle from a skipping rope fitted by Kieran. Cotter pin to lock down the brake button. Priceless. (Well, maybe $10 parts + a welding six pack).
Simon
USUK Racing
October 07, 2011 07:44PM
low tech for the win!
October 07, 2011 09:06PM
Three hose clamps! Waaaaaaaaaaaaaay high tech! They're stainless too!
Come on low tech would be 3 zip ties and a lotta duct tape!
(which I wrap below the botton, then tape the button down, that's low tech--even if the Duct tape i use came from the aborted Nuke-u-lar powerplant at Satsop, WA)(So in the hierarchy of duct tape its pretty top drawer stuff)
October 07, 2011 09:14PM
YES! That just made my Friday night.
October 07, 2011 09:26PM
Whatt did??
A spikkin a witch, what's youse got in the mighty 242 for handbrake?
October 11, 2011 06:47PM
Whatt did??
The pic of that cool home brew handbrake extender was the high point of my Friday night. Sad state of affairs, eh?
The Midnight Pumpkin has the stocker handbrake with tight cables, combined with my Popeye forearms it works fine (been doing some concrete work recently, anyone want to arm wrestle?)
BobOfTheFuture
Rob
None, anymore.
October 11, 2011 07:21PM
simoniac
Simon
USUK Racing
Simon, Every time I pull the brake in my SVT daily driver I worry, Seeing how it flexes, that I might break it. Thanks to you, I worry no more... thumbs up
October 11, 2011 09:32PM
was the integrated CNC one good on quality? i ask since the other version can accept a wilwood and if the one they provided is iffy, there is no way to work it. (seemingly)
October 11, 2011 10:05PM
No problems with mine in 2 years. Still works after wadding the car.
October 12, 2011 07:14AM
what's the weight of the CNC staging brake?
DirkaDirkaJack
Jack Russell
phil's GTI
October 13, 2011 09:51PM
i had one from checkpoint racing (i think) in the mazda. it was the shop in colorado. is that checkpoint? anyway, here is the best pic i could find that is already on the internetz. the stick needs a shift knob, which it doesnt have in this pic.
Edited 1 time(s). Last edit at 10/13/2011 09:52PM by DirkaDirkaJack.
