Max
1983 MKI GTI
Brake lines exterior to interior
November 14, 2011 11:59AM
Im looking for picks on proper ways to bring hard lines in. Think i found a pic here,
http://www.rallyanarchy.com/phorum/read.php?5,38131,page=5
Looks like some simple plumbing parts given they match the line size?
Robert Culbertson
Out of this dumpster fire
Re: Brake lines exterior to interior
November 14, 2011 12:36PM
Are you going from hard line to hard line, or hard lines to flexible lines? When I needed to go through the cowl, I just drilled a big hole and then used a grommet to seal it. $0.10 compared to $10 for a bulk head fitting.
Max
1983 MKI GTI
November 14, 2011 12:57PM
I have hard line. I was thinking of hole/grommet but was curious as to vibrations eventually wearing down the grommet.
Robert Culbertson
November 14, 2011 01:33PM
Wear is a simple fix! All you need is some gasket sealer/tape/gum/poop and you're good to go. If all else fails, just throw another grommet in there.
November 14, 2011 04:20PM
Yeah, grommet is what I used. The only bulkhead fitting in the brake system on my car is from the rear of the shell to the flex line that goes to the axle. (which is then hard line again)
November 14, 2011 10:23PM
There's the answer. Timm used a grommet and has had zero problems with it.....
November 14, 2011 11:31PM
Bwhahahahahhahahahahhaa!!!!!!!
November 15, 2011 10:00AM
Pointing and laughing like Nelson " Ha Ha"..... Burn.
November 15, 2011 04:04PM
Oh, how cute, someone thinks I know the answer to everything!
No, but seriously, nice. Well played hahahaha
November 15, 2011 06:31PM
i tried the whole grommet fad, damn thing just popped out the other side.. eventually i went with fuel hose profiled and wrapped around the brake line and stuffed it like prom night with silicone lube. no need to get fancy bulkhead fittings, try to keep the number of failure points down.
November 15, 2011 06:40PM
Disagree. You need 2 bulkhead fittings, 4 nuts, and 4 slieves to do the brake lines properly. It makes the line much easier to make, leaves a cleaner install, and can do a much better job of keeping mud, water, dust, and FIRE from making it's way through the firewall. And it costs lkess than $20 to do it right.
Ian S
Ian Seppanen
1991 Nissan 240SX
November 15, 2011 08:58PM
Did this for the pass through from the engine bay to the wheel well for the front brakes. Working great so far.
Max
1983 MKI GTI
December 07, 2011 01:09PM
Do you guys/gals run the lines dual-single thru the valve the single-dual out? Do you run this setup internally for both front rear?
December 07, 2011 02:02PM
Twin masters. One line out of master to a T to for front and rear. Rear T is behind rear bulkhead with one line in interior. Same when I had single master. One line through the cabin.
December 07, 2011 06:21PM
Hasn't rubbed through yet!thumbs up smiley
