Removing spare tire well
Posted by Racinkid13
Max
1983 MKI GTI
November 17, 2011 11:48AM
the roll cage thread got me thinking. This was something I had been thinking about. As JVL so candidly pointed out, the accumilator on the mud bunny is in a rather precarious position. Thinking of replacing the well and repositioning the accumilator and spare tire mount similar to in-bed mounts on 4x4 rigs.
replacing with plate steel? pretty integral to structure?
stupid idea? somewhat plausible?
Re: Removing spare tire well
November 17, 2011 12:41PM
Max, that spare tire well is the ideal place to mount your 2 fuel pumps and the big Bosch filter. Its low so fuel spills can drain, and its a snap to close up, and seal for rules and stink.
Note: 2 pumps.
Tom Burress was just a few miles from winning Doo-Wops overall a couple of years ago when his single pump puked. he had 2 spares in the truck. Didn't help when the car puttered to a stop on the last stage.
2 in the car, one in the truck would meant a great win for the Rare-bit.
Instead a Volvo 240---with 2 pumps in the back---won.
I'd concentrate on somewhere else.
Armor the front edge with a layer of .062 or .088 and call it good.
Put the effort into moving the pumps and line inside where they're safe.
Max
1983 MKI GTI
November 17, 2011 12:52PM
seal? like constructing a latching door? or just a removable panel?
fliz
Chad Eixenberger
1988 VW Golf #687
November 17, 2011 01:00PM
I'm doing a removable panel on mine.
Bushore used part of a 55 gal. drum to seal his pump. He also mounted the pump to the drum so it's easy to pull out and work on/swap.
November 17, 2011 05:29PM
Some 1/32 aluminum sheet with some aluminum L pieces pop riveted on for strength and 3-4 Dzus or 1/4 turn fasteners. maybe a strip of cut up mouse pad glued on for fumes.
Cheap. easy.
November 17, 2011 09:28PM
Yeah,,,aluminum,,,or al-youminium as they on BBC. Get Grant to cut a big circle with his Skil saw.smiling smiley
November 17, 2011 11:01PM
Better yet, get Tim to spend eight hours and fifty blades to do it with a jig saw!
November 18, 2011 06:20AM
Better plan, I'll use our plasma cutter!
November 18, 2011 06:22AM
(And I bet you could cut a spare tire sized circle out of 1/16 in under 1.5 hours with under 3 blades.. with a jig saw... tongue sticking out smiley )
(But I would use our plasma cutter with the circle cutter compass thing.)
mack73
Jason Wine
November 18, 2011 07:53PM
Hum... 3 blades huh.
Well I did mine in 0 - blade still works fine :p
Beat that
-Jason
November 18, 2011 08:00PM
Who said the cover has to be round?
November 18, 2011 09:22PM
Who said it didn't ? I guess it could be a trapazoid, I'll bet Timm could cut one of those with a Swiss Army knife.
November 18, 2011 11:19PM
I'm not sure about the swiss army knife. It would have to be one with a nail file at least.
Maybe Al could get the swiss army wood saw to work?
DirkaDirkaJack
Jack Russell
phil's GTI
November 20, 2011 08:00PM
my fuel pump recently died while ironically driving the car to the gas station, and after monkeying around with the stock fuel pump location, i decided it was about the worst place for it.
i built the fuel pump box into the front of the spare tire well, as the back has the battery box. i think this was much easier building two sides of a box instead of 5, if it was on top of the shell inside.
if you dont cut out the spare tire well, i think this is a pretty good use for it.
Edited 1 time(s). Last edit at 11/20/2011 08:16PM by DirkaDirkaJack.
November 20, 2011 08:10PM
Just what was it about your driving that made it ironic?confused smiley
