So after all these years, the Babushka Fuel Cells apologies to the babushka dolls John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Doivi Clarkinen Banned Mod Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
There are carbon fiber fuel cell enclosures that are FIA legal. You see them all the time in FIA GT and prototype racing. The Ferrari F430GT that I worked on in the ALMS in 2007 had 2 fuel cells (right behind the bulkhead on either side of the engine) in carbon fiber cases. Also, when our driver hit the wall and destroyed the car while in the lead in its second race the car caught on fire (duh, it's a Ferrari) and so did the fuel cell case a little bit. Somewhere I have pictures. The corner marshals put out the fire right away but the fuel cell on that side got scorched and we had to replace the carbon fiber cover.
As Bob pointed out carbon fiber doesn't burn but the epoxy resin holding together does. A good fire will burn all the resin out of a carbon fiber part just leaving the cloth behind that you could practically reuse. |
Ascona73 Bob Legere Ultra Moderator Location: Spofford, NH Join Date: 03/07/2007 Age: Ancient Posts: 310 Rally Car: 1971 Opel Ascona |
I'm sure the FIA specs are pretty tough too. Probably must tolerate a given temperature before catching fire and must not give off toxic fumes as the epoxy burns away, blah, blah. Probably not within the realm of a DIY'ers garage-built carbon fiber fuel cell. Opel is a 4-letter word... http://www.flickr.com/photos/10498579@N07/sets/ |
A1337STI Alex Rademacher Ultra Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
I remember seeing the fuel cell in a Subaru WRC as being something similar - saddle shaped tank, and IIRC it stuffed up underneath the car with a big carbon skidplate to protect it. No can.
Carl S Carl Seidel Junior Moderator Location: Fe Mtn, MI Join Date: 02/10/2006 Age: Midlife Crisis Posts: 765 Rally Car: 1993 honderp |
Gravity Fed Alex Staidle Elite Moderator Location: Δx = ħ/2Δp Join Date: 08/21/2009 Age: Midlife Crisis Posts: 1,719 Rally Car: Various Heaps |
okay just so i under stand things...
lets say i have this cell (pic below). It as a cell, with a steel casing. The steel casing would need another fireproof casing? or just the filler parts? Because i have the understanding its like the picture on the bottom.
![]() First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
bknblk2 Tony Wood Ultra Moderator Location: Wichita Join Date: 02/02/2009 Age: Possibly Wise Posts: 181 Rally Car: 83 Citation "Oskar" |
ah okay thats more reasonable than i thought. i was convinced the steel casing needed a steel casing. I am working with a hatch back.
Basically the passengers compartment has to be 'safe' from fuel spills, fumes or leakage. The normal steel container can be used in a hatchback with either a compartment seperator or a small box built over the fuel fill area. The upper seam on the tank should be sealed with a fire stop sealer and the tank should have a drain installed that goes thru the floor.
It just isn't the big hassel some people like to portray. FIA rules are rather specific about installation in 2 box cars and where the fill can mount (so it isn't easily ripped out in a side swipe for one). Older sedans like many Mazda, Datsun and even Audi had the fuel tank in the truck and seperated with only the back seat. Cars like this need the whole trunk sealed off and the C pillar opening into the pass compartment, even with a stock tank. We've been lucky with the fire thing to date. Luck isn't any sort of guarantee nor should it be used as an example of something being allowable. Look how many car fires are on the news regularly or how many we've seen in person along the freeway. There have been many racers badly injured or killed thru fire with good cells, response crews and everything done right. |
do you have links to the FIA requirements for remote fill location? I planned to mimic the WRC rx7s and have it in the rear 1/4 window.
