mellow65
Oliver Klozoff
Nada
The old timers keep on telling me I have it backwards, pfft, what do they know grinning smiley
January 15, 2012 10:56PM
Don't think I ever shared this video, but here's the monstrosity that I drew out in my head about 2 some years ago finally coming to life for the first time. grinning smiley
I call it a Mazdaru. smiling smiley
Better than Sub-duh.
mellow65
Oliver Klozoff
Nada
Re: The old timers keep on telling me I have it backwards, pfft, what do they know grinning smiley
January 15, 2012 11:12PM
Lol grinning smiley
Idk that sub duh has a good ring to it. smiling smiley
biggreen96
Chris Caylor
Old Legacy- not very stock.
Yeaaaaaaa!
Brap Brap.
January 16, 2012 10:31AM
So Matt, what's the purpose?
AWD RX7? Rally car? Weight?
mellow65
Oliver Klozoff
Nada
January 16, 2012 11:31AM
So the point was to see if I could do it, it's rwd and utalizes a w58 celica trans, yes to being a rally car, and should be just over 2000lbs.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
January 16, 2012 12:54PM
Niice! it didn't want to start at first (confusion) but it sounds great...
subaru ECU? did you just ignore any of the chasis inputs (door sensors , etc) ?
mellow65
Oliver Klozoff
Nada
January 16, 2012 02:29PM
A1337STI
Well the motor hadn't ran in over a year and I think my starter is about to take a dump on me. So yeah a combo of that makes it a little grumpy to wake up. but now it fires right up no issues.
I'm actually running a full chassis and engine harness from a legacy wagon. I spent the better part of a week removing all unneeded plugs and systems from the harness. It's really the bare basics now, lights, instruments, and engine. And the best part is i don't even have a check engine light on after my swap. I mean sure, clearly there isn't a code for "hey muther fuker, i'm in the wrong car". smiling smiley
here's some pics from my build.
a entire harness in a bucket
be afraid be very afraid
the unused pile of wires
laid out testing
set up in the car
legacy cluster and headlight and wiper stalks
subaru in tank fuel pump in rx7 tank, so functioning and accurate fuel gauge
the question everyone ask, what about the clearance
stock hood clearance
looks at home in the engine bay.
January 16, 2012 02:44PM
A mind is a terrible thing to waste....winking smiley
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Congrats on getting it started. That engine is surprisingly far back and low in the engine bay. Probably close to the length of a rotary.
Have you done the math on the weight different between a fully dressed fuel injected 13b with transmission vs. your set up?
I still think you're nuts, but to each their own. That's just unnatural. But at least it will be unique.
A1337STI
Alex Rademacher
January 16, 2012 04:34PM
That's Awesome!!!! grinning smiley
I've found the subaru short intakes work best if you make any sorta 'scoop' in the front and make a box around the Cone filter. So you have a ram air, to your short intake . I did that on my STI and the cone Temp went from 105F to 74F on a day when it was 70 degrees outside. I tested with a pyrometer and the 2 tests were with in 10 minutes of each other on the same stretch of road. and same time idling before and after. i was really shocked. (but happy)
I modified the above radiator ram air intake of the STI go to into a home made "air box" basically i just recreated the subaru factory setup with out the silencer and a higher CFM capacity air filter.
Awesome! Awesome!
Tell me this car will be at rally idaho or mendocino this year!! Please ! Please ! Please !
mellow65
Oliver Klozoff
Nada
January 16, 2012 06:21PM
Andrew_Frick
Heres a side shot of the engine bay and the handle is showing the center line of the front wheels.
The last couple figures I found of weights of fully dressed 13bs put them in the mid 400lbs. As for the Subaru motors I could find some stuff for ej20s coming in around mid 200lbs. So I have to imagine I'm losing a good 200lbs. The trannys have to be pretty close, or at least my back tells me they are about the same.
January 16, 2012 06:51PM
mellow65
Awesome!
That will be a fun car! People can talk shit all they want, but a good 2.2 engine provides alot of fun. I've wanted to do this in a Starlet for a long time.
January 16, 2012 07:14PM
Bravo!
