somepants Jeff McMillen Ultra Moderator Location: Seattle Join Date: 12/15/2011 Age: Possibly Wise Posts: 36 Rally Car: 87 Subaru RX |
The fan-thrown debris would keep people from trying to overtake you on stage. So there's one advantage. I think it'd be a real engineering challenge to build adjustable side skirts to keep the suction contained on the varied terrain of a typical gravel special. I can only imagine the undercarriage chaos on a "yump" as the skirts try to deal with the lack of ground to "effect".
Landings would be different. Not so much rebound. And water crossings. Whoo hoo! --Jeff |
mellow65 Oliver Klozoff Ultra Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
Heres just a random engine bay shot while I was out figuring out how to still make my headlight go up and down.
It all fits in there quite nicely. Used a stock shorty rx7 radiator and Subaru fan. That's also a legacy booster and master cylinder. Just molding of 2 worlds. ![]() ![]() "Rally racing makes a heroin addiction look like a vague craving for something salty" |
do what i did. Weld the lights in the up position and take the motors out.
I had thought about doing that but I want to be able to put them back down. And even if I have to build some small latching thing to do it I probably will. It's that or like a plexy glass cover with a smaller style light behind it.
Doivi Clarkinen Banned Ultra Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
Come on a rotary has a whole huge pile of steel inside and iron housings, 2 of 'em, Subaru has this tiny little cast iron crank with little 6mm thick counterweights and wimpy ass 130,5mm rods and 23mm pins and thats it inside for steel (aside from some tiny valves and springs and retainers OOoooo). X volume of mostly aluminum and a few spindly pieces of iron and steel vs a whole lot of BIG iron and steel parts...of similar volume...., come on the Subie thing has to be a whole lot lighter---a LOT. Its like Ford guys saying the 2,3 SOHC weighs the "same" as a big iron V8....with bigger crank, with 4 more rods, 4 more pistons which are bigger, another lump of iron for a head and essentially most of another block, also made of iron, and sometimes even a big wide IRON intake manifold, and 2 exhaust manifolds... Logic doesn't apply when boys sit down to the keyboard. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
mekilljoydammit Super Moderator Join Date: 09/22/2010 Age: Midlife Crisis Posts: 336 Rally Car: No rally car yet |
Heads, cams, valvesprings, some other shit... and I'd guesstermate the Subaru engine is about twice as wide too. Most of the iron bits on the rotary are pretty hollow too.
Actually, I have a broken down EJ25 and a built 13B (and a Toyletta 3S-GTE but ain't noone arguing those are light) sitting around in my barn, and a set of longacre scales. If anyone's really actually that curious I could go risk frostbite and weigh shit tomorrow night-ish. |
Exactly. The rotary may be small, but it's DENSE. No big airspace inside like in a piston engine, it's all iron and tiny air gaps and maybe a few slivers of really expensive aluminum.
Well, you may be right when it comes to normal V8s, but the *5.0* engine (not the 302, they are different) was an exercise in how much weight can be removed from an engine and still allow it to run, mostly. They went to a huge external imbalance just so they could remove a bunch of weight off the counterweights of the crank (and the cranks still break). The engine block is thinwall struts holding the main bearings to the deck surfaces and not much in between. Boring any more than .030 is iffy, the blocks warp and stretch, and they quite literally split down the middle at torque levels that a 2.3 would laugh at. The weak spot isn't the stock compressed-cheese rods or the cast pistons, it's the block itself... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 01/19/2012 07:25AM by Pete. |
