John...I stumbled on this; What about the fuel??????
Posted by Mylesofsmyles
Mylesofsmyles
Re: John...I stumbled on this; What about the fuel??????
March 30, 2012 12:11AM
I may have broken some ground and found the fable fuel pumps...
Mercedes 300E and 300CE's have a nice tray under car, housing a pair of Bosch 0 580 254 950, nice fuel filter and accumulator....this is off a 3.0L inline 6-cylinder K-Jet car. The assembly, with it's beautiful hard lines fits right onto a 240 fuel pump tray!!!
The inlets on the fuel pumps are 14mm, and are said to be used in the same configuration on the AMG E60. They're rated for 135LPH each....
Should be enough for my lil Turbo toy?
March 30, 2012 12:35AM
Mylesofsmyles
Yeah, I betcha if youse slook you'll see that is more than enough..
Mylesofsmyles
March 30, 2012 12:38AM
Werrrrdddd...
Oh, what about the accumulator?
Is it worthwhile to retain in the setup?
March 30, 2012 01:01AM
Mylesofsmyles
Werrrrdddd...
No, just keep it simple.
Mylesofsmyles
March 30, 2012 01:06AM
I'm going beyond my knowledge with this, so reel me in homie....
The accumulator is cuz K-Jetz gotta maintain fuel system pressure so importantly...
Isn't that sorta, kinda, maybe like a swirl pot idear???
Like make an already good system, just a lil bit better?
Seeing as though I never really ditched the accumulator setup from when the 242 was K-Jet.....meaning the return line, from accumulator to tank....
I dunno, I'm all for simple, but if it's just one lil old line to hook-up...that's already there, might be worth it???
March 30, 2012 12:40PM
Just go efi!
I've got a set of 5 370cc injectors-bosch style connectors
your choice of haltech or megasquirt both currently in fuel only form. MS is upgradeable.
I'll even throw in a known good fuel pump.
Mylesofsmyles
March 30, 2012 01:53PM
I have gone the route of EFI. I've been running BOSCH LH.2 since November 2010.
I've now swapped to MS1v3....the addition of the accumulator, would just be an extra measure to maintain consistent fuel pressure.
March 30, 2012 02:59PM
well nevermind then.
Mylesofsmyles
March 30, 2012 03:07PM
Just thinkin, in terms of maintaining residual system pressure.
Might be nice for start-ups.....
Gotta look into it a bit more though, because I could swear there's supposed to be a check valve in the system, somewhere.
March 31, 2012 10:07AM
The check valve is the pump.
The accumulator is there mainly for noise supression, not for maintaining pressure. The pulse waave through the fuel lines when the injector opens/closes can cause a knocking noise. You will be fine without it.
March 31, 2012 12:30PM
Accumulators like to fail anyway.
March 31, 2012 01:33PM
Everything fails, thats why I said fergheddit since it is not needed.
Mylesofsmyles
April 01, 2012 11:09PM
Werd....
Suppose you're right....not to mention, the accumulator is there for start-up on a K-jet car....it needs that reserve...won't have that issue.
I cut the Accumulator clamp off the Mercedes-Benz Fuel Delivery tray....so, now just a pair of pumps and a filter....gotta grab a hard line connector off a later, EFI Benz, one without the accumulator output, and I'm set.
Funny, I grabbed all the hardware to hang it, from the Benz, it fits up where the old pump on my 242 goes, perfectly, and the old tray from the 242 makes a perfect skid plate.
Mylesofsmyles
April 10, 2012 11:07PM
Confirmed this setup is also used on the w124 400/420E...a 4.2L V8 making about 275hp/295ft.lbs.
Rumored to be used on a few current/recent AMG models too.
Still no 044's on stock Benz's yet
April 10, 2012 11:46PM
Do you still need a friggen fuel pump? I've got one sitting on the floor of my garage. Worked just fine till the fuse box decided to go to hell in a fiery mess. (meaning still works great) It's the backup to my to my backup, but I'll give it up if you are crazy about the idea.
