I may have broken some ground and found the fable fuel pumps...
Mercedes 300E and 300CE's have a nice tray under car, housing a pair of Bosch 0 580 254 950, nice fuel filter and accumulator....this is off a 3.0L inline 6-cylinder K-Jet car. The assembly, with it's beautiful hard lines fits right onto a 240 fuel pump tray!!! The inlets on the fuel pumps are 14mm, and are said to be used in the same configuration on the AMG E60. They're rated for 135LPH each.... Should be enough for my lil Turbo toy? |
Yeah, I betcha if youse slook you'll see that is more than enough.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
No, just keep it simple. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I'm going beyond my knowledge with this, so reel me in homie....
The accumulator is cuz K-Jetz gotta maintain fuel system pressure so importantly... Isn't that sorta, kinda, maybe like a swirl pot idear??? Like make an already good system, just a lil bit better? Seeing as though I never really ditched the accumulator setup from when the 242 was K-Jet.....meaning the return line, from accumulator to tank.... I dunno, I'm all for simple, but if it's just one lil old line to hook-up...that's already there, might be worth it??? |
aj_johnson A.J. Johnson Super Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
Everything fails, thats why I said fergheddit since it is not needed. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Werd....
Suppose you're right....not to mention, the accumulator is there for start-up on a K-jet car....it needs that reserve...won't have that issue. I cut the Accumulator clamp off the Mercedes-Benz Fuel Delivery tray....so, now just a pair of pumps and a filter....gotta grab a hard line connector off a later, EFI Benz, one without the accumulator output, and I'm set. Funny, I grabbed all the hardware to hang it, from the Benz, it fits up where the old pump on my 242 goes, perfectly, and the old tray from the 242 makes a perfect skid plate. |
Do you still need a friggen fuel pump? I've got one sitting on the floor of my garage. Worked just fine till the fuse box decided to go to hell in a fiery mess. (meaning still works great) It's the backup to my to my backup, but I'll give it up if you are crazy about the idea.
