Ford 8.8?
February 05, 2012 12:21PM
so after endless googling, debating and whatnot.
The ford 8.8 95+ explorer, 31 spline axles, disc brakes.
I can likely find one for a good price. Its the exact width for the Rx7, has discs, has 5x4.5 lug pattern, has 8.8 aftermarket, has lots of gusto and is only about 30lbs heavier than an 8" toyota.
Question. C-Clips? Apparently, the disc caliper would hold an axle in. There are eliminators only for drum brakes, but a friend recommended milling the space needed for the discs to attach (as they share attachment points). Would this even be needed? Or at least good insurance to try?
Re: Ford 8.8?
February 05, 2012 01:21PM
The reason the eliminators don't work with disc brakes is because the disc brake has an internal drum parking brake that takes up most of the space between the axle and the housing.
The parking brake also usually doesn't work because it's seized into oblivious and the shoes have come apart, so as long as the backing plate bolt pattern is the same as drum, I don't see why it wouldn't work.
Re: Ford 8.8?
February 05, 2012 01:40PM
hmm. well i would ditch such a parking brake apparatus as i have a lever that uses physics to generate braking force.
Re: Ford 8.8?
It seems most of the Ford 8.8s are offset, one side longer.
Also its a lot of overkill.
30 lbs more than Toyota which is 17-18 lbs heavier than Dana 30 which is a real good upgrade for Mazda or Toyota 5.2" or whatever they are.
So Toyota is already a real BIG upgrade.
Toyota LSDs out of the Supras are 4 pinion diffs: 2 side gears and 4 pinions is better than 2 side gears and just a measly 2 pinions..
The bearings are larger in Toyota...
Aside from a little machining, the Toyota seems to be to be more reasonable, and is common enough.
Re: Ford 8.8?
February 05, 2012 01:49PM
the mazda rx7 is a 7" I believe the Dana is 7.2?
The Toyota would still require machining, then i have to figure out the brakes. Not sure how that offset thing would affect everything... I just need to find a 4 speed 2wd and toyota would get cheaper.
The 8.8 is just nice since it has all the stuff ready. less customization = less cost and profanity?
I could use a Turbocoupe 8.8 axle 87-88 which is equal length, use two short side ranger axles for 5x4.5?
Edited 1 time(s). Last edit at 02/05/2012 01:49PM by Gravity Fed.
Re: Ford 8.8?
February 05, 2012 03:57PM
Damn, I forgot about the offset. Yes the 8.8 out of the Explorer has a pretty decent pinion offset to the right, probably for more fuel tank room since American trucks all stick the fuel tank on the driver's side (a broken driveshaft will be less likely to whip it to death there, is my guess).
Meanwhile, someone on that forum did some measuring and found that the 2wd Toyota truck puts the pinion about 3/4" to the left of where the RX-7 has it, which by providence means that the Toy will actually center the driveshaft under the tunnel. I have lots of pinion marks on the right side of my tunnel where the flange smacks into it, and I keep forgetting to clearance it every time I have the pumpkin out.
So, size and shape wise, advantage: Toyota.
Disadvantage, is the Toy rearend costs more, and then you have to put a diff in it, where even I can find 4.11 limited-slip Explorer rears for $150-200 a pop. (Last time I checked for '95-earlier 2wd Toy rears they were $300-500). And rebuilding the Track-Lok is pretty easy and cheap.
Re: Ford 8.8?
February 05, 2012 06:47PM
I got toyota rear end, I think its an early 80's 4wd with a 4.10, for $100 dropped off in my driveway. And I'll probably just end up welding the diff, at least first, so no need to buy a separate lsd right off the bat.
Edited 1 time(s). Last edit at 02/05/2012 06:48PM by Carl S.
Re: Ford 8.8?
February 05, 2012 09:17PM
LSD from Supra, the whole stinkin things can be had for $50-200, matches the Ford but with a 4 pinion design. Win.
Choose your Toiletta right and you can get the ring and pinion as short as 4.88 stock.
Stock.
Win win win.
Edited 1 time(s). Last edit at 02/06/2012 08:04AM by john vanlandingham.
Re: Ford 8.8?
February 06, 2012 02:11AM
fine fine fine, ill see what the junkyards give up to me when i get home. Pull a parts are full of toyotas here.
Re: Ford 8.8?
February 06, 2012 09:43AM
I got a toyota axle, and the lsd diff from a supra together for $200. it took a little searching, but not much.
Re: Ford 8.8?
February 06, 2012 09:53AM
But you haven't sent the half shafts up yet..
I's gunna be doin some other bolt circle type stuffs real soon, be smrat to have yore sheet here same time...
Re: Ford 8.8?
February 06, 2012 09:55AM
Oh Johny of the Chips, you really going to drill those holes someday?
Re: Ford 8.8?
February 06, 2012 10:06AM
Oh yeah,
I have the now empty supra diff case. Its free to a good home. Its not that exciting without the diff in there, I konw, but someone might want it.
Re: Ford 8.8?
February 06, 2012 11:22AM
Yeah, and you could send the diff case and associated junk-n-stuff with it
alosix
Jason Powers
Re: Ford 8.8?
February 06, 2012 08:48PM
Damn near got my finger stuck in an 8.8 tonight.. That's what I get for using it to check fluid level.. That would have been a fun one to explain to the extraction team.
1.) If a dana 30 is sufficient (coming from my Jeeping days, that is just so hard to see) then an 8.8 in stock form is way overkill, no need to go looking for c-clip eliminators.
2.) If by some stroke of luck you are breaking shafts, Superior Axle and Gear was making a 'Super 88' kit for a while. Came with some nice billet contraptions to hold the bearings. It did make the axle a bit wider, but it helped me clear a lot of things easier with the tires a hair futher out.
3.) Glad you got it figured out.
This isn't floor mat anarchy
