Dimple die
Posted by ChrisKobi
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
Dimple die
February 27, 2012 02:42PM
I'm looking for anyone (in Seattlish area) that has a 1.24 and 1 inch or so dimple die that may want to punch out 24 holes. I'm making my gussets and well, money is getting thin right now, would gladly get you a 6 pack or something. (I plan on buying some dimple dies but they are ridiculas in price.)
I can have the holes drilled and just ready to punch.
I was considering just doing the notch at the bar intersections to view welding but the dimple die looks better.
Thanks Chris
alosix
Jason Powers
Re: Dimple die
February 27, 2012 03:04PM
There's a guy on pirate that's been selling packs of dimple dies at a pretty decent price (that I can't recall, but I'm cheap and plan on getting a set smiling smiley )... Currently out of stock I believe though.
http://www.pirate4x4.com/forum/showthread.php?t=871560
This isn't floor mat anarchy
Edited 1 time(s). Last edit at 02/27/2012 03:05PM by alosix.
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
Re: Dimple die
February 27, 2012 04:17PM
alosix
Thanks for the link, thats a great deal!
Re: Dimple die
February 27, 2012 04:36PM
I'm a cheap bastard when it comes to tools sometimes.
Made with a 12mm 1/2" drive socket and a piece of roll bar tubing in the vice. Also, a hammer was involved.
Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
Re: Dimple die
February 27, 2012 04:40PM
Well now that's a good case of the ends justifying the means!
Jay Woodward
Snohomish, WA
Chronologically, 46...
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: Dimple die
February 28, 2012 07:51AM
Dave what did you use to cut the holes? Was it just a hole saw?
Re: Dimple die
February 28, 2012 08:56AM
Has anyone used the new type of hole saw with the carbide cutter teath? Do they run true?
Robert Culbertson
Out of this dumpster fire
Re: Dimple die
February 28, 2012 10:47AM
I've used some hole saws that were ground tool steel, and they were incredibly true. I measured to hole after the cut and it was only 0.005in over (used a hand drill). The carbide ones, I assume, will also run true since they are machined and not rolled.
Re: Dimple die
February 28, 2012 11:06AM
Of course the screaming question is: wot da fock is the concern about tolerances when using a fockin hole saw?
You need tolerances you use the right tools: drill, broach, bore.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
Re: Dimple die
February 28, 2012 11:46AM
Are those gussets now required? cages in 08 / 09 didn't require gussets but all of the new ones have em.
are gussets super cool these days. should i get some added to my car?
Re: Dimple die
February 28, 2012 11:57AM
A1337STI
In RA since the change to FIA 253 gussets have been required. Believe that was 2005 or 2006 rulebook. On the main hoop X, door bar X, a-pillar reinforcement to door bar (even if not intersecting), and roof X if done. Two per junction.
Hence why the a-pillar intersecting the door bar means less fabrication.
And why a V in the roof means less fabrication.
I've always thought it'd be funny to the the gussets and two corresponding sides instead of across from each other. It's not specified technically. smiling smiley
Re: Dimple die
February 28, 2012 01:12PM
I asked Hurst about that and I was told they could be on the same side. I think that's what I'm going to have to do with the BMW...or cut the door bar mess out and start over.
Re: Dimple die
February 28, 2012 04:44PM
Andrew_Frick
Unibit.
sidewaez
Blake Lind
orange AE86
Re: Dimple die
February 28, 2012 06:25PM
If you want to spend a little money on some dimple dies I think it would be hard to find a better value than these:
http://www.ebay.com/itm/3pc-Conduit-Size-Dimple-Dies-Set-1-2-3-4-1-/160725166469?pt=Motors_Automotive_Tools&vxp=mtr&hash=item256bf76985
They are conduit sizes which is a bit misleading but since nothing has to pass through the holes it doesn't really matter. The advantage is that you can buy a Hydraulic Knockout kit from HF that will punch the correct size holes for these AND you can use the hydraulics to make the dimples too.
http://www.harborfreight.com/hydraulic-punch-driver-kit-96718.html
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
Re: Dimple die
February 29, 2012 08:17AM
sidewaez
that seems pretty cool, I like the hydrolic punch.
