Basic measurements for them fancy 4 links
Posted by mellow65
alosix
Jason Powers
Re: Basic measurements for them fancy 4 links
March 09, 2012 10:34AM
Would the axle shift be the basic reason for the Watts link then? Never really dug thoroughly into that idea?
Yeah.. a watts link would cure that, as well as a triangulated 4 link (without a panhard bar).
Nothing like getting used to driving a twin 5 link (4 link with panhard) vehicle.. When I first got my little Jeep it could do 1/2 a lane change on its own when crossing bridge expansion joints. Eventually you get used to it and compensated, but the first few times its fun.
The longer the panhard and closer to level it is at ride height should lessen the effects though.
This isn't floor mat anarchy
sidewaez
Blake Lind
orange AE86
March 09, 2012 10:49AM
alosix
Yeah driving a car that's incredibly stable over bumps on a gravel road does take some getting used to.
alosix
Jason Powers
March 09, 2012 11:08AM
sidewaez
alosix
Not trying to say it can't be properly sorted or that it isn't on most cars. The stock Jeep TJ configuration was good for some surprises under the right circumstances. Heck.. the rear suspension would torque bind and with a little practice you could carry the driver's side front tire for quite a distance in a completely stock vehicle.
March 09, 2012 07:26PM
Keep in mind that the Watts linkage presents some challenges for rally. One side of the linkage sits low, and you have to have a long, very strong vertical anchor point sticking down low on one side of the car for that lower link. Can be pretty exposed to damage for rally. Panhards are much simpler. My old Opel rally cars never acted up with them with fairly long travel, so I'll stick with that design.
March 09, 2012 07:32PM
no plans here to go to a watts, Charles has gone that way and I was just trying to see the advantages.
Zap zap my ass...
mellow65
Oliver Klozoff
Nada
March 09, 2012 07:49PM
Actually I have no beef with the watts link, and the geomatry works out better when you really start talking about axles movin up and down, ie the axle not shifting from side to side because of the pan hard bar getting shorter.
At least in the case of the rx7 the watts link is placed fairly high on the axle, making the lower link about parallel with the axle center line. It actually sits on the front of the axle so the upper link has to go over the 3rd member. All in all it keeps it out of the dirt quite well.
I was talking to Hurst at mt hood last year about his old rx7 and he said the watts works well for him, and once he ditched the upper bars in favor of a single 3rd link the whole rear axle worked a millions times better.
As for charles watts link, yeah I think a simple pan hard bar would have worked the best for that, but twas not my money or car so to each there own.
March 09, 2012 08:37PM
Well there you have it: no advantages, so of course that's the thing to do.thumbs up smiley
This is one of those things which crop up constantly.
Fred has some shit standard set-up. Researches and sees that Watts is theoretically a better set up...
And the truth is............. it is....but is: extra cost, extra fab, extra maintenance, potentially more shit to go wrong and be worse when it isn't tip top enough an advantage over a much simpler to fab and do panhard rod which is already a big improvement over the crap he had?
Its the "a good plan today is better than a perfect plan tomorrow" deal.
A good panhard rod has let 10s of thousands of guys drive their cars faster and harder than any of us ever will.
Good enuf.
RallyTaco
Chris Lanctot
just a wannabe
March 09, 2012 10:23PM
alosix
I think that has more to do with a Jeep being a torquey short wheel base vehicle than the 5 link setup. Leaf sprung CJ's used to to this too. You could do a 'Michigan Left' in one of those things and not drop the left front wheel down until you let off the throttle or had to shift.
[jvl] Ohh noooohs! There's an h'off tawpik thread in the gent-urinal dick-cushion four-hum. THINK OF THE CHILDREN!!![/jvl]
Edited 1 time(s). Last edit at 03/09/2012 10:29PM by RallyTaco.
mellow65
Oliver Klozoff
Nada
March 09, 2012 11:48PM
Good enuf.
For sure if starting from scratch the need to build a watts links isnt there, you can have a pan hard bar and it's done and done.
But that's kind of the path his car took, the "simple" volvo build ended up being, well, not very simple any more.
It should be interesting, WHEN it gets to some level of completion.
March 10, 2012 10:46AM
i have a major beef with the Watts, since when you combine it with upper link(s) that actually allow the rear suspension to move, the back end does a bunch of unsettling things over one-wheel bumps, since the roll center is so far away from the lower links' plane.
It's not easy for me to describe it, but it's like the toe changes a bunch because the high Watts is making the axle swing to the side over one wheel bumps. A Panhard more inline with the lower links eliminates this.
March 10, 2012 01:03PM
Thanks, Pete, and good info for all; I wondered when someone would figure to mention this. A Watts linkage moved up vertically to reduce damage from the road is typically attached to the top of the pumpkin. If I remember right (and feel free to check; it's been a while), that moves the rear roll center up along with the attach point. On the 50 series Opels (first Manta and first Ascona models), the axle end of the panhard rod connects into the axle at almost the exact height of the 2 links, all of which which are below the axle's center line. Keeps the rear roll center lower....Putting a Watts linkage center attach point that low is just about impossible.
March 10, 2012 02:24PM
The way I'm picturing the suspension moving, on a one wheel bump with a Watts, the axle rotates around the center pivot, and if that center pivot is pretty high up, the axle swings to the side.
With a Panhard, on a one wheel bump, the axle rotates around the chassis end, or the axle end, depending on which side it is. It doesn't make the rearend doe-see-doe.
It's not *just* the roll center height, it's the pivot height in relation to the trailing links, and how those angles are all interrelated. The RCH isn't strictly the location of the Watts/Panhard, it's where the axle intersects a line going from the centerline of *that* device to the centerline of where the trailing links are pointing, and if that line is angled, then the axle is going to want to *move* along that angle.
Sure, the Escorts used a Watts... they also put it dead center of where the four parallel/even length links were. Well engineered setup, in other words.
I'm not an engineer, I just put stuff together and see what it does, and then learn why it works well or works awful.
Edited 1 time(s). Last edit at 03/10/2012 02:27PM by Pete.
mekilljoydammit
No rally car yet
March 10, 2012 11:08PM
Just to throw it out there, I know of at least one application of a watts having the pivoting section horizontal instead of vertical, on the bottom of the diff. Needs Heim joints and probably not too applicable for rally, but it's at least possible.
SteveL
Steve Leitch
Can't decide which to use...
March 11, 2012 12:24PM
The outfit that designed this (2 brothers out of SoCal) for early Mustangs...
Not much good for Rally, but could be killer on tarmac ...
SteveL
