Basic measurements for them fancy 4 links
Posted by mellow65
mellow65
Oliver Klozoff
Nada
March 01, 2012 12:12AM
Does anyone know what how wide you are supposed to put the boxes and how far forward the boxes sit in front of the axle center line?
Just looking at the rear axle and behind the seat area and wondering where it all would sit if I did it someday.
Re: Basic measurements for them fancy 4 links
March 01, 2012 12:43AM
Matt, I made some Sooooper Bitchin stainless plug in spacers for the 3/4" rods ends I've used and I thought, "Wull, i can make these any width but if'n I stink a little I could bump up the production run and use the same thing in another application, lemme see hmmmmmmmmmmmm, OH! I gots sit! I'll make them same width as Xratty front control arm inner bush for that day I make some 606 copies of the Ford 909 arms! I's fawkin bwiwiant!"
That's what I thunk. So I made them 60,1mm wide.
Now since them I found some burly rod ends with rubber bushes so I wuz thinkin----always a danger sign---why not use rubber at one end for a little cushion. I'll check those tomorrow. Gotta finish dinner at 10:45 cause I been down making a jig from welding Ian Seppanens Nissan 240 strut ears on.....
Earliest I've been home for a week.
mellow65
Oliver Klozoff
Nada
March 01, 2012 01:00AM
What the frick width is 60,1mm?
I'm not so much wanting the box width (which I'm assuming that's code for), but the "hey I'm looking in the back seat area and there are these 2 weirdo boxes, they look to be ________ inches apart"
March 01, 2012 01:50PM
mellow65
On the width, it depends on where you put the brackets on your axle. Here they are placed 9" out from each side of the diff housing: http://www.rallyanarchy.com/EscortRallyPrep/Suspension%20Rear.pdf
As far as how far foward the boxes sit, according to the same document, the equal parallel arms are 25.5" from center to center.
sidewaez
Blake Lind
orange AE86
March 01, 2012 06:16PM
the "frame rails" on the car will sort of dictate how far apart the boxes will be. length can vary from car to car. the corollas use 24" long links and volvos are more like 28".
March 01, 2012 06:25PM
Like Wlison said, the width apart is going to be determined by things associated with the axle and the car's under body structure:
- Axle locations where you can put the brackets
- Where in the floor you can put the long upper boxes. Generally, this is limited by the subframe/unibody rails in the backseat area
- Where under the car you can place the lower anchor brackets; this may be wider than the uppers to get a solid anchor point.
Make them as long at you can allow with everything else. You can tie in the upper box forward ends (where the multiple holes are located) to a horizontal bar welded across the main hoop of the cage to strengthen it all up. Keep uppers and lowers equal length and make them as level as possible at static ride height. You can look at how circle track racers use unequal equal length and angled links; makes sense for acceleration only off of left turns. Makes no sense for left and right turns on uphill and downhill; and with braking action in all sorts of conditions.
On my never moving Opel Manta project the link are 24" center-to-center (I mistakenly reported 28" recently); the uppers are 25-1/4" apart, and the lowers are 36-1/4" apart. The forward links ends are rubber bushed, and the back ends are heim joints.
Mark B.
Ascona73
Bob Legere
1971 Opel Ascona
March 01, 2012 06:35PM
Mark B.
How IS that Manta project these days Mark? Same place my Ascona project is most likely!
FWIW, we are entering my friend's Ascona in the all-tarmac Rally New York in August. Should be interesting...
Opel is a 4-letter word...
http://www.flickr.com/photos/10498579@N07/sets/
March 02, 2012 09:17AM
Hey Bob,
Going nowhere; too much to do to keep work/business going, and my wife and I picked up another hobby that eats up time and attention.
Good deal on the Ascona entry! Hmmm, I may be tempted to come up.
Regards,
Mark B.
Ascona73
Bob Legere
1971 Opel Ascona
March 02, 2012 11:27AM
FWIW, I pretty much have the engine done for my rally Ascona. Got a Ford T9 gearbox core after looking for years too. Suspension is all done. Just gotta get the shell finished and painted and assemble it. That's 'all'....winking smiley
bknblk2
Tony Wood
83 Citation "Oskar"
March 06, 2012 08:19PM
I'll probably be asked to turn in my rally card but I have been know to, sparingly, watch, rarely, not very often, the Sat morning shows on Spike. One of the shows, Xtreme 4X4 has a host Ian Johnson that is, oddly enough, quasi-intelligent.
Sometime in the past they were building a tube buggy/trail runner. He gave a long chalk board monolog on the math of suspension design. It was really interesting. Minor changes in the length/ geometry of the four links have a significant effect on rear squat/traction/axle wrap.
Maybe it's on the internet somewhere???
alosix
Jason Powers
March 06, 2012 09:10PM
bknblk2
If you go hunting around the internetz for a '4 link calculator' you'll probably stumble across something that'll do the math for you.
Met Ian & Jesse @ Sema a few years back. Both pretty entertaining. Got a picture of the crew with Jesse somewhere.
This isn't floor mat anarchy
RallyTaco
Chris Lanctot
just a wannabe
March 07, 2012 12:08AM
bknblk2
Watched an Xtreme 4x4 that was the culmination of some big multiple episode build up where they built a custom tube front end with custom multi-link suspension for something. They took it out to test it and half the suspension welds failed almost immediately. It was hilarious.
[jvl] Ohh noooohs! There's an h'off tawpik thread in the gent-urinal dick-cushion four-hum. THINK OF THE CHILDREN!!![/jvl]
SteveL
Steve Leitch
Can't decide which to use...
March 07, 2012 12:23AM
All the maths you need are here...
http://www.racetec.cc/shope/
Good luck...
SteveL
jrally
Jon Rood
'94 Escort GT (sold)
March 07, 2012 09:15AM
My off road / mad max / motorstorm / rally chase vehicle (Celica) has unequal length arms, and aren't parellel to each other either. I followed the off road truck race design. With heim joints at 6 of the 8 locations, I get no binding, no loss of acticulation and TONS of traction. I've never had the axle hop often associated with live rear ends axles. Ideally, I would have made the arms all about 20-30% longer, but space was an issue, as well as maintaining the factory lower front pivot. The big problem with this set-up is, I have 9" of travel with a pan-hard bar, so the axle shifts under the body a good bit. Either I adapted to what it tends to do off jumps right away, or the shifting just isn't that big a deal. I hear the tires lightly hitting the body at full compression and full droop, but the car never tries to dart one way or the other because the the axle shift.
-Jon
March 09, 2012 10:30AM
Would the axle shift be the basic reason for the Watts link then? Never really dug thoroughly into that idea?
Zap zap my ass...
