Re: Suspension for an '88 323 GTX
April 30, 2012 07:17PM
riponfrosh
I have no intentions of competing with the 323. I have a Miata-shaped money pit that keeps my pockets empty enough as it is. I mainly just wanted to get the 323 back to streetable condition. It is certainly drivable, but not what it once was. Perhaps i should sell it? Not to turn this into one of those "What is my car worth" threads, but being as these are so rare (at least in most circles) i really don't know what it's worth. It has 84,000 original miles. The interior is MINTO and the body is straight. Runs well, had the crank replaced under warranty back in '91 (have paperwork.) Also had the clutch replaced not many miles ago, but IIRC it slipped a bit the last few times i had it out. It did sit for MANY years, not sure if that had anything to do with it. Car runs well, and always starts right up. I sure would appreciate a few knowledgable appraisals.
Here is a link to some pics.
http://www.flickr.com/photos/tryourcoffee/4001412949/in/photostream/
well you're the hard type of customer to make happy...
The "Green Meanie Söspendös" are good and can be tailored to exactly what you want, they are expensive..
I'm faced with the same quandry with road car Xratties and Volvos: there's nothing worth a damn between cheep cheep KYB and my stuff..
The OE type Bilsteins for both those are valved so soft that you quite limited what spring you can use before it overpowers the damper/insert..
Of course that's presuming one gives a shit about suspension that works good cause its a constant battle and a continual sadness to see poor bastids like I just saw today on Merkursprout who was the 6th person who used the exact phrase "I hate driving my car now". He listened to deluded people, bought rear springs more than 2 1/2 times stiffer than original in the rear, and short 8" springs in the front....insta-coil-bind...
So I can do you stuff that not only make the car handle like never before, but is still reasonably comfy on normal speeds on normal roads.....and corner enough to start popping the spotwelds in the subframes front and rear...
mekilljoydammit
No rally car yet
April 30, 2012 07:37PM
Actually, funny anecdote, John. Poking around and found our RX-7 setup book; done by a former vehicle dynamics engineer at GM who actually plugged shit into calculators, tried the shit to see what works and to evolve the models, and in the process was basically behind the design on all the front running 1st gen RX-7 roadrace cars in the country... copy we found was revision 25 and that was from '03. Spring rates he was reccomending for roadrace cars on prepared race tracks, with goddamn slicks putting 9" of rubber on the ground, generating something like 1.5g lateral grip? Around 450 front, 275 rear.
Why everyone gets so obsessed with astronomically high spring rates...
fliz
Chad Eixenberger
1988 VW Golf #687
May 01, 2012 09:05AM
You should rally the GTX.
Or at least hit up a WAG event and find Erik Zenz...he's in Milwaukee and rallies a 323 GTX.
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
May 30, 2012 04:09PM
mekilljoydammit
You wouldn't happen to have these in an electronic format would you? I would like a "looksee" if that's okeeday.
"The more I learn, the more I realize I don't know and have so much more to learn." - Claude Rouelle, Optimum G lecture June, 2011
mekilljoydammit
No rally car yet
May 30, 2012 08:17PM
I'd actually have to have a think on that. On the one hand, it went for monies (not gigabucks, but like $95) until fairly recently, and I don't want to take cash out of the guy's wallet when he's been genuinely helpful, and kindly asked at the time of writing to not spread it around... but on the other hand he's getting out of the business. Not trying to be a dick or anything, etc, just slightly odd situation for me to just say yes.
http://www.gforceengineering.net/ is the guy's site. Maybe drop him a line if you're that interested.
May 30, 2012 10:09PM
mekilljoydammit
Goood.
God.
That boy wants a lot for his stuff...
What do those Koni double adjustable inserts cost? Just the inserts?
$650 for speherical bearing top mounts? How do I do 'em better for $200?
$350 for carving up old cast iron flywheels...
I've been packing NEW STEEL ones that went for $300
Did 10 and sold out in under 2 days so did 25 more..
Guess its better to goes out of business.
mekilljoydammit
No rally car yet
May 31, 2012 06:39AM
The RX-7 shit anyway, the struts are actually a wet housing conversion not just DA inserts; no idea on the Fiat stuff, but the price he has listed is about what Truechoice or the like charges to do the conversion. Looking at the Fiat stuff a bit, inserts are $300-350ish apiece... plus whatever for springs and the strut tubes (figure you'd know that off the top of your head better than me) so wotever. Never tried to price out Fiat stuff, so no idea what else is available in that price range. I know for a competitive 1st gen RX-7 roadrace suspension in what SCCA classes exist for the things in this country, he has/had the least expensive *competitive* setup available.
Maybe there's a killing there to be made selling Bilstein based stuff, by someone who knows what they're doing valving Bilstein based stuff, to roadrace guys. Friends of ours recently upgraded to Dynamic struts/springs which are on the order of 10k new... for the 1st gen RX-7 for example, there's not much availabe in the range between "street shit" and that, but the chassis is still out in front setup right and with the right driver.
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
May 31, 2012 09:37PM
mekilljoydammit
No totally. Don't worry about it. I'll figure something out about it, either buy it from him or not. We'll see. Thanks.
