Yeah the gap you indicated.
OK in future, don't fawk with the gas, you can piss away the whole volume in one bad chuck application.
Man I serious pull my hair out and chain smoke and slap the UPS guy when I wait 2-, now three months on Bilstein.
7 months for thos guys, I hear 6 months for Karl Jardevall to get is EVO Proflex rebuilt, 6 months for some RSSPSSPSP
All that for SERVICE!
I'm making the whole gawddamn thing, all the parts and I don't take that long....
Too long in my opinion sometimes, but not that long..
I feel for you. (There. through common ground of suffering delays we share something together...See? I can can poke fun at you and others but its not mean its poking fun cause we've all be fawked and had many of the same bad experiences. Brotherhood via misery. Understanding via emapthy.)
SeanP
John:
I did cycle the stroke. There was no evidence whatsoever of oil leaking around the shaft so that is good. I was under the impression that the shaft should automatically extend once i shoved it into insert. I put the nut back on the end and held it in my bench vise and pushed pulled a few times. This is when I discovered the gurgling noise in the remote res and discovered the leak from the fitting. I am trying to get KW to fedex me another hose and fitting so I can install that and figure out the methodology and capacity of filling the right amount of fluid in the res.
If I understand you on the long shoe horn, I am slathering grease down into the body so it fills the voids between the bushings in the body. In between the red arrows on the pic below
The PSI was for the nitrogen charge of the resevoirs. KW literature says about 145 PSI. This is in line with some of the sway-a-way coilovers I have run in the past (160sih-170ish).
KW made these shocks for the car about 8 or more years ago when dodge commissioned these neons to be built. supposedly they were the shit at the time, or so the prior owner of my car told me. Honestly, I am looking forward to these new bilstien inserts and getting some new suspension made when I get some cash next year. Until then, these will have to suffice.
