John Reed
John Reed
Toyota AE86
Brake questions
June 09, 2012 04:30PM
So after Oregon Trail, I decided the first thing that I wanted to change on the Corolla was brakes. Mostly it was a pedal feel (start pumping it early to see what would be there when you needed it) but figured while I was at it I would look at just getting more brakes on the car.
RX7 4 piston front calipers are the cheapest/most common upgrade and I have a set of those but the question I have is: How much clearance do most consider acceptable on a rally car between the caliper and the wheel (I am thinking both for rocks getting up in there, and wheels getting bent)? The RX7 calipers are a tight fit inside my 14" wheels, leaving about 1" between the inner bead and the caliper (most likely spot to bend) and a gnat hair in the inner part of the wheel.
Other options are keep the stock calipers and rebuild them and run good pads, or look into going to 15" wheels (not sure the car has suitable room for that, and I lose a lot of spare wheels it came with).
Thanks in advance!
John Reed
John Reed Racing
www.johnreedracing.com
johnreedracing@gmail.com
Re: Brake questions
June 09, 2012 04:43PM
What kind of budget do you have? There are a few different brake kits out there for AE86s.
Also, how often were you bleeding your brakes? Did you try that to regain some pedal feel? Had you bleed them before the rally?
Edited 1 time(s). Last edit at 06/09/2012 04:44PM by Dazed_Driver.
John Reed
John Reed
Toyota AE86
Re: Brake questions
June 09, 2012 04:51PM
I didn't have a set dollar figure in mind. The main goal was to just improve them, without wasting money. I have found a lot of options but the 14" wheels are the roadblock I keep running into. The RX7 setup seems to be the best bang for buck, they do fit the 14" wheels, but there is not much space left inside the wheel in the event something gets bent up. I have seen other rally cars where they run them pretty tight, so maybe it is fine like that. I guess the main goal is always, just don't bend stuff up. HAHA
I looked at a Wilwood caliper which would probably fit nice with a custom bracket but wasn't sure how important it would be that it doesn't have dust seals like an OEM.
I have seen your build on EvoM, car is very cool!
John Reed
John Reed Racing
Edited 1 time(s). Last edit at 06/09/2012 04:52PM by John Reed.
alosix
Jason Powers
Re: Brake questions
June 09, 2012 04:54PM
Not 100% sure what's considered acceptable clearance, but my 40mm offset (vs 53 stock) Team Dynamics 15s vs a stock WRX front caliper just barely clears and I doubt I'm the only one with this combination.
I'd wonder if you can bend a rim in an area that would affect caliper clearance without royally fubaring the car/wheel/corner in the process.
This isn't floor mat anarchy
Re: Brake questions
June 09, 2012 08:34PM
John Reed
Thanks!
grp4fabrications does have two AP brake kits. One is said to fit under 13" wheels. They probably mean motorsport wheels like a mini light or something, however, they would probably fit under stock 14s.
I made a custom Wilwood set up for my fronts, however, if it proves to not work out, I'll be going to that AP kit.
http://www.grp4fabrications.com/product_info.php?cPath=42&products_id=428 <- that is the kit.
Obviously, it's AP, so its a bit spendy. But, it's AP... so its quite nice. The conversion rate isn't TOO killer right now, but I have no idea what shipping would be like. Nor do I know if you can piece together everything in that kit save for the brackets and buy just them. Also, if you can, you could always MAKE your won brackets and run a wilwood/ap/whatever caliper.
mellow65
Matt
Nada
Re: Brake questions
June 09, 2012 09:42PM
An inch is probably more then most people have. The 2 pot Subaru non wrx calipers really take up most all the room under a 15" rim. then there are 15" rims out there that fit over wrx calipers, and with street rims you need 16s to clear them.
I say press on, and just stick with tough 14" rims if you are really concerned about it. Personally I wouldn't give it two thoughts.
Re: Brake questions
June 09, 2012 10:38PM
Hmm... read that wrong. I read ".1"...
About how much is a gnat's hair? Literally almost nothing? You might consider just a 1/8-1/4" wheel spacer maybe, to move it way.
I thought you "needed" 15" wheels for the rx7 calipers? What wheels are you running?
mellow65
Matt
Nada
Re: Brake questions
June 09, 2012 11:14PM
It would depend on the rotor at that point. If he's doing rx7 rotors then yes he will need 15s. But if he's making the 4 pots fit on his stock rotors then he probably would be ok.
Re: Brake questions
June 10, 2012 12:11AM
Ooooh, ok. What sort of rotor is an RX7 front? bolt on the hub style?Or does it slip over the studs?
mellow65
Matt
Nada
Re: Brake questions
June 10, 2012 12:26AM
They slip over the studs.
John Reed
John Reed
Toyota AE86
Re: Brake questions
June 10, 2012 01:51AM
Those AP brakes are so sweet! I wish my budget had room for those....
The RX7 brake setup everyone seems to run (at least that there are off the shelf brackets available for) use a Honda Civic rotor that is bigger than stock AE86 but obviously smaller than the RX7 rotor. With this setup they will fit certain 14" wheels (I have stock GTS wheels), but not all and if they do the space is very tight.
John Reed
John Reed Racing
Re: Brake questions
June 10, 2012 02:01AM
Yeah, I plan to run pizza cutters. I would try the wheel spacer, then. You keep the wheels/tires, but gain some clearance on the thin side.
sidewaez
Blake Lind
orange AE86
Re: Brake questions
June 10, 2012 11:41PM
Yeah the brakes were always a conundrum on the corolla, it's too bad there's not a ton of room for 15's. Would try the rx7 stuff, because if it doesn't work there's a good market to sell it off and you can return the calipers to the parts store.
You're already running wheel spacers right? I think for pedal feel dual master cylinders would help the most, at least that's the next upgrade we planned to make to the car.
I also have rebuildable calipers and rebuild kits that come with the car.
mellow65
Matt
Nada
Re: Brake questions
June 10, 2012 11:55PM
Any one have info on what Adam did on his? Didn't he end up doing Volvo stuff up front?
Re: Brake questions
June 11, 2012 12:51AM
mellow65
I'm not sure. I seem to recall his did something like an entire volvo upright swap? Maybe?
I'm not sure about the rears either... if I'm remembering right he used the volvo wheels, so he could keep the volvo calipers, as they're 2 pots and too wide to fit into a corolla wheel. Or something. They didn't fit...
