Budget Rally Computer/Dash Display?
Posted by NoCoast
July 17, 2012 03:54PM
I saw a Finnish M3 build that used this instead of stock cluster.
http://trailtech.net/motorcycle_vapor_kits.html
Seems affordable and easy. Any thoughts?
Re: Budget Rally Computer/Dash Display?
July 17, 2012 05:00PM
I have hd a couple trailtech speedo's on my motorcycles. They do last, work great, but are tiny! The one I have also lets you program maintenance reminders by time and mileage.
July 17, 2012 06:08PM
Yeah. The M3 they had had an alt trickle light, temp warning light, shift light, and Vapor dash. I guess in theory you really just need the warning light and shift light for when on actual stage?
July 17, 2012 06:31PM
Thats why I am loving the Stack we put in Derik's car. Very bright warning light that comes on when shit gets over/under what you program it to do. The $1,000 it costs is steep, but really, you could spend 4-500 on quality gauges. It does fuel pressure, oil pressure and temp ( I added a rotary switch to select engine, trans, or diff temp with a sender in each) coolant temp, tach, shift light, and speedo.
Rallyst165
Joel Pacello
July 17, 2012 10:54PM
Which model stack is in Derik's car Sean? Was it $1000 total cost? I've been looking at the Racepak IQ3 http://www.racepak.com/IQ3Dash.php for the celica. Its like $655 for the cluster and then another $300 or so for the adapter to hook it up to the AEM ems-4.
Edited 1 time(s). Last edit at 07/17/2012 10:55PM by Rallyst165.
July 18, 2012 01:35AM
It is one of the lowest spec ones. He got it from the guys at DSG for a good deal. It is so awesome though....
July 18, 2012 08:33AM
I've used the trailtech on my old cb400. Real neat units, but they really aren't very big. Got a link to the m3? I'd be tempted to put one in the 80 to avoid having to buy a speedo and tach.
July 18, 2012 10:40AM
What about those AIM kits as well? I was looking at doing a bunch of gauges and then when the total comes up to a few hundred bucks, I thought the same, and might as well just get a decent replacement display.
wildert
Brian Klausen
VW Golf GTi 16V
July 18, 2012 11:06AM
I have a similar kit in mine - no rev counter in that though because I wanted a "regular" one - so it's just for gas, speedo and a few other bits and bobs.
Works fine...
Brgrds
Brian
July 18, 2012 12:31PM
If you are running an ECU which can spit data to the AIM it's very sweet!
I ditched 4 gauges, and replaced them all with an AIM Strada MXL. it integrates with my Vipec ECU, and gets all it's data from there. I did add a couple sensors to the vipec for things like oil pressure and oil temp, but that certainly was no big deal.
It's super easy to read, and the warning lights are very tough to go un noticed.
July 18, 2012 12:40PM
One problem is that you cannot reset interval mileage very easily. Back when the Trailtech (it is also a bicycle computer under a different name, I forget what)first came out, which was also in the days of routebook only rallying, I contacted the manufacturer about changing the programming but it was not something they could do easily.
wildert
Brian Klausen
VW Golf GTi 16V
July 18, 2012 01:40PM
Oh yeah - now I remember the brand of mine: Acewell smiling smiley
Brgrds
Brian
July 18, 2012 02:46PM
Woah! those AIM's aint cheap!
July 18, 2012 02:56PM
What was your total end price on that strada? I've been looking at racepak and aim because I've also got a vipec. Mine is the v44.
July 18, 2012 03:24PM
It was about $1K give or take a few bucks, the only thing other than the dash you need is a $20 cable from your vipec dealer.
I weighed all the options of Racepak and AIM, and also spoke with my tuner who has used both dashes, and he highly recommended the AIM.
