GM Ecotec and MA5
July 24, 2012 09:17PM
Have lined up the I-mark (aka Kadett C) through a bud who just lost his garage space. Want to put in a 2.4 ecotec bottom end with 2.2 head and max it normally aspirated within reason. Aisin wide ratio ar-5 (gm ma5) is the readily available tranny that bolts up (also found in variations in Toyotas and isuzus). Also aisin Ay6 may work.
Feedback please.
Re: GM Ecotec and MA5
July 24, 2012 10:50PM
http://quad4rods.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=29&category_id=4&option=com_virtuemart&Itemid=100041
600 bux is a bit spendy for an adapter (I'm a cheapskate) but probrably cheaper than finding the trans from a solstice or sky...
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
July 25, 2012 07:03AM
Is the 2.2L head that much better than the 2.4L. Why not just run a 2.4L all the way?
I am assuming you have read this
http://gmtunersource.com/racertech/ecotec-build-book
July 25, 2012 07:18AM
AJ - also in the Chevy Colorado truck so oodles of the around.
Andrew - because the 2.4 head is vvt and the 2.2 is not. Seen the gm book - thanks.
July 25, 2012 09:43AM
RWD? What's gear ratios? Bellhousings available?
SgtRauksauff
Jorden
July 25, 2012 10:15AM
Gear ratios (Canyon, Colorado, H3):
1 2 3 4 5 R
3.75 2.26 1.37 1.00 0.73 3.67
Gear ratios (Sky, Solstice):
1 2 3 4 5 R
3.75 2.26 1.51 1.00 0.73 3.67
http://en.wikipedia.org/wiki/Aisin_AR_transmission
AY6:
Gear ratios:
1 2 3 4 5 6 R
4.17 2.19 1.49 1.19 1.00 0.84 3.67
Applications:
2004 Holden VZ Commodore
2005 Cadillac CTS
2005 Toyota Tacoma (including the X-Runner)
2006 Holden VE Commodore
2006 Lexus IS220d
2006 Lexus IS250
2010 Chevrolet Camaro
2010 Lexus IS200d
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
July 25, 2012 10:33AM
Those ratios make me feel better about the BMW ratios...
4.23, 2.52, 1.66, 1.22, 1.00
At least they are a decent 1-4.
The GM ones would be good if you have a rear end that you can get a numerically higher number final drive. Give you a trailer loading first also and manageable 2-5 at 2.26, 1.51, 1.00, 0.73.
Edited 1 time(s). Last edit at 07/25/2012 11:08AM by NoCoast.
July 25, 2012 10:43AM
6 speed and skip 1st.
4.88 back axle
July 25, 2012 11:17AM
I was looking at ratios like this...
5 speed
3, 4
1.51, 1.00
6 speed
3, 4, 5
1.49, 1.19, 1.00
Just adding a gear change between the two...
Rev drop 3-4 with the 5 speed is 7000 to about 4600.
Rev drop 3-4 with 6 speed is 7000 to 5600
Then 4-5 with 6 speed is 7000 to 5900
So I guess the question is, does the car pull hard enough from 4600 to 5900 to negate the added gear change. So really comes down to how peaky the motor is and/or how expensive the 6 speed is compared to the 5 speed.
July 25, 2012 11:39AM
5 speed
3, 4
1.51, 1.00
6 speed
3, 4, 5
1.49, 1.19, 1.00
No, it comes down to the 5 speed being a really wiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiide ratio box that will fall on its face every shift..
I mean fuuuuuuuuuuck.
July 25, 2012 12:03PM
How does this compare?
Ford T5
2.95, 1.94, 1.34, 1.00, 0.63
0.65, 0.69, 0.75, 0.63
0.59, 0.65, 0.74, 0.82
GM 5
3.75, 2.26, 1.51, 1.00, 0.73
0.60, 0.67, 0.66, 0.73
GM 6
4.17, 2.19, 1.49, 1.19, 1.00, 0.84
0.53, 0.68, 0.79, 0.84, 0.84
July 25, 2012 05:16PM
Rear end will be Chevy 7.5" 10 bolt as found in many s-10 blazers.
July 25, 2012 05:19PM
Oooooooooooo. I think that's one that my favorite 5,1:1 ratio is available.. That'd work good in a 2nd thru 5th box.
Veeeery good..
July 27, 2012 04:39PM
A new bellhousing for a Solstice/Sky is a hair under $400, and you can use Toyota W-whatever transmissions.
That's NEW, as in plonking down your money at a dealership.
Edited 1 time(s). Last edit at 07/27/2012 04:40PM by Pete.
July 27, 2012 08:49PM
Here's what you do:
Get cleaned up all respectable like and mozey down to the dealer and say "Gee, golly, I SHOOOOOORE like the looks of that baby, I's itchin to buy one but I wanna take 'er for a little test drive"
You hop in and be calm and check what's behind ---maybe another one of the target car---if you're lucky--- but it in reverse. Stall once, fire it up then FLOOR THE FAWKER, dump clutch and slam into car 2. HARD, Lurch forward and smash into another car. Start screaming "I had my foot mashed hard on the brakes!!! OOoooooowwwww my neck, my neck!!"
And splain you din't like the upholstery color anyway.
Have a confederate follow the tow truck to the scrapper when they total out the cars..
Go to junk yard and pull bellhousing and pay $15 each. Now you have a spare, too.
Works everytime
