Seat bracket/mount advice
Posted by BJosephD
Re: Seat bracket/mount advice
October 19, 2012 05:29PM
Just make sure you do a better job of that than these guys:
Seat pulled thru the washers that were on the floor, or something like that.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
October 19, 2012 06:16PM
The picture makes it look that way a bit but I don't believe that to be the case.
Pretty sure Sean's pictures are just tack welded in place, but technically the seat would be held in place by 8 little welds, not 2. smiling smiley[/quote
Good point. I failed at counting. I figured it was part way welded I just wanted to double check.
Chad, Thanks for the photos and the description of your setup.
