I worked a BMW program last summer where I got to drive/hoon the V8 M3 and several 335 cars (some auto, some manual). Loved the power delivery and that little "woomph" from the exhaust pipe of the turbo cars on upshifts, but can't imagine spending that kind of money on a car to get to work and back. My current daily driver is a $3k beater legacy wagon with a JDM swapped EJ20...probably spent too much on that and certainly spent too much time on it. Big issue to be aware of on the earlier model 335s is that they had lots of problems with the fuel delivery system. Dave |
Dave, Derik's E36 M3 came in under 2500lbs on street tires with no spare and tools. Something like 2460, so there is plenty of weight to remove.
Okay, here's some pictures...
![]() ![]() Disassembled diff: ![]() ![]() ![]() A little short on plates. Belleville washer, steel disc, and friction plate. That's it on this side. Didn't dig in to see if other side is the same. ![]() ![]() 45 degree ramp angles on accel and decel. ![]() Obligatory Merkur photo... ![]() Grant Hughes |
Grantie-poo dahrlink, this is your chance to set the diff pre-load and stack the plates for max grip..
There should be a small washer in a recess that you can swap or add shims under, maybe 020" and up the breakaway torque.. You familiar how to do this? If you're going to be fucking with these things you oughtter get an extra output flange thang and weld a bug 1" or 1 1/4" nut into the middle , then you have sumpin to put the torque wrench on when checking break away.. You know what I'm talking about? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 01/09/2013 03:02PM by john vanlandingham. |
Yes. There was a little shim under there already. So adding shims there will increase the preload by increasing pressure on the outer ring of the Belleville right?
I'll have at least two extra output shafts so will weld on a nut ASAP. What's thought on modifying ramp angles to get less lock on decel? Grant Hughes |
No, but you could machine the top plate down a bit to fit more plates in. If I'm lucky the 4.10 diff I'm grabbing tomorrow will also be a LSD one and we can entertain that possibly... What would be the benefit of more plates? Grant Hughes |
More surface area over which to spread the locking. I think that helps with operating temperatures and probably longevity, may also allow you to have it lock harder, but not sure if that last one is something we need offroad. |
Some other research indicates they "might" be the same as Porsche diffs internally? Emailed our local Porsche differential specialist to see if he knows anything about that. Also to see if he can supply plates. Not sure how to assess the quality or need for replacement of the plates in the diff either.
Grant Hughes |
^^^ ![]() ![]() You could always ask Patrick Snijers to test the diffs for you. He certainly is a man who could chuck a BMW around. Check him out laying down the rubber as he test his diff! In fact the kid in the other thread who trashed his daddy's M3 was probably trying to emulate the master himself... (and failing). Disappointingly not yet a Jackass Edited 1 time(s). Last edit at 01/09/2013 05:08PM by danster. |
E30 and tarmac. yawn...
![]() Just met the guy with the quicker and linear Z3 rack. So I got that now also. The stock rack is progressive and slower ratio. Increase of about 40% with the Z3 rack and got it for pretty cheap AND the guy delivered it to me. Sweet. Gonna take the diff up to a friend who's company makes Porsche diffs and gearsets once I get the ring and pinion I want to use. Hopefully next week sometime. Will post pictures of course. Hopeful we can get a few more plates in and test breakaway and get a decent setup worked out. Grant Hughes |
I did find a great 15 minute vid of BMWs on both gravel and tarmac but thought it a bit long to post. Just wanted to show a diff working.
I have been reading up on the few BMW topics and threads on here and it certainly makes me think there is a lot of potetinal in them. We have plenty E36 including compacts over here available for very little money. In fact even the later E46 are now turning up for around a 1000GBP. When I look at the older mk1 & 2 VW platforms I muck around with and compare them to the more modern cars I really see how the strength of the shells has improved. This has got to be a major safety consideration. I pulled some panels off a mk4 golf last year and behind the outer sills it was incredible to see the way it was put together and how strong it was. I'll presume BMWs of that era are pretty much the same as they were all passing similar crash tests. And I would go as far as to say that a mk1 golf with a basic cage might just be as strong as a mk4 golf without one. Disappointingly not yet a Jackass |
Danny, modern shells are strong in just exactly the way the need to be for the US DOT or EU crash tests..
Years ago I was reading a German mag about this and the figures ---Germans really do love figures----showed yep if you smack a car into a solid concrete wall exactly square, at 50km/hr---31 (English) mph for youse 9duddn't that piss ya off that you have to use ENGlish miles?) ---everything is just marvelous But figures show cars hitting things at a slight offset were killing the drivers even in big supposedly best safe cars like big Mercedes, big Bee Em, big Lexus, all full of airbags etc.. Modern CAD with FEA capability alows designers to make stuff "strong enough" in the intended usage and that means a car driving straight ahead going to get groceries.. An excellent example is the Frod Fuckus rear suspension. OK to go straight down the road. pure unadulterated ka-ka against any side loading. Wanna see piccies to illustrate? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
