$100?? ASAP? The fact that they haven't requested is is no point, they didn't think of it and as a shell prep guy you should educated them... 2 pieces of tube 18" long cost $100? Why are you arguing? It's simple and makes shit stronger for hardly any weight or bother. This is hard? ![]() John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John is right here and not just for his example of strut-tower forces. That bar also helps keep the sill-bar and door-X in tension during a side impact instead of just pulling the foot of the main-hoop forward. At the front end of the car, a tube from the foot of the A-pillar to the top of the strut tower does the same thing at that end....
OK, don't see it. You can learn Grant by asking "I wonder why Ford always put a bar from base of main hoop upwards when the rules don't require it?" And on my cage its a total of 2 x 32" or 64" or about $52 if it was 4130 CrMo bought in short quantities...but it ain't or $28 for DOM Mild Steel Tube A513 TYPE 5 (just happen to be ordering steel for the next run of 50mm things cause all the tubes I have for 50s are standard length for normal fronts and Subies rear and BMW fronts need a longer tube....) You don't want to...fine. I was suggesting to Mark John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Well that settles it. The Ford guys OBVIOUSLY had engineered it and designed it and realized that without it EVERYONE would die and the rule makers were stupid for not requiring that single bar! Grant Hughes |
It is certainly interesting looking at the cages you guys are fitting and how there is a lot more to them than is required over here in the UK.
I have not yet seen this years MSA rule book, but unless there has been a drastic change then just a basic six point cage with single door bars with regard to the cage is all that is needed to get the car logbooked and out on stage. The curved non intersecting door bars pictured, and the discussion on them at the start of the thread makes sense. I have considered the benefits of having a slight convex bend (facing outward) in certain tubes that would need to compress first to go "over centre" before it started to encroach in on the occupants space. The door bars and roof section of the main hoop seem places this would be a possible benefit. An impact at these points would need to push and move the supporting tubes of these curved members to allow the length to be wide enough to let the member go "over centre", where as a straight tube can just start bending inward from the start. Think I might check with my local technical scrutineer on a whether the curved door bars can be used here in th UK. Disappointingly not yet a Jackass |
TronDD Tim Meunier Mod Moderator Location: Boston, MA Join Date: 10/27/2011 Age: Midlife Crisis Posts: 252 Rally Car: 96 Subaru Impreza |
No, a straight door-bar tube in a door opening strike with a tree is in tension immediately upon impact. ---Yet another reason to use the diagonals from the feet up to the strut towers both front and rear. The curved outward tube is first in compression between the main hoop and front stay but has a tremendous amount of leverage due to the angles and moves over-center with very little resistance before coming into tension. And, once it come into tension, the twisting and deformation associated with coming over-center has weakened at least one element (the tube, or one of its connections, or connected tubes) and thus compromised the total tension load it can support before failure. This is why NASCAR bars are frowned upon and require a lot of additional tubing (mass & connections together) to be certified for US rally. Straight bars (or at least all bars in a single plane between the main hoop and front stays) in the door opening... Please ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
Nice explanation. Here's my favorite "thinking outside the box" cage recently... Keep a close eye on the green bars... ![]() ![]() We chatted about his design and he modified and ended up with this. ![]() Grant Hughes |
You know that makes perfect sense. I can grasp the high leverage aspect and the resultant slack then needing taken up. Straight bars as you describe are effectively in tension the whole length between the shock towers offering a pretty large area of support to absorb the force. It's always good to hear different views as it helps to build the fuller picture and understanding. ![]() And the good thing is no pipe bender is now required by me as a bonus! EDIT, Blast! Well no pipe bender till Grant posted that pic! ![]() Disappointingly not yet a Jackass Edited 1 time(s). Last edit at 01/23/2013 04:41PM by danster. |
No Ford were bright enough to think beyond the rules about ROLLOVER protection for the occupants---which may possible never come into play---and think about shell stiffening and shell longevity.. The age does one passive thing--save your life, and one active thing, save the shell's life every time you pound it. Grant you're arguing like a keyboard Honda hero.. You know 99% of people I've gently suggested that they might want to consider that little bar have kinda squinted, had a revalation (you can see it occuring, there's a skrunched look the their face goes calm and then a smile) and they say "Oh yeah I can see how that works, yeah!" You mad, brah? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
really simple a straight door bar hitting a tree is in tension.. Straight beam is stronger than an arch, that's why bridges are always made without arches, right? wait ![]() Simple. Uh wait.. ![]() But but but! ![]() Generally compression for a tube secured at the bottom like this II the force going V thataway.. And generally tension is for a tube like this secured at the bottom force going thisaway ^ doorbars being hit seems to me like its mainly perpendicular or nearly so, so bending force ----->ll seems the largest factor . So an arch bent outwards has a shorter straight part, that's stronger. And the arched shape itself IS stronger---we've known that since pre-Roman times although they really went to town with arches, and the arched outward shape absorbs and disperses energy further away from the bodies in the car and that can't be bad... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
darkknight9 Kirk Coughlin Infallible Moderator Location: Saint Paul, MN Join Date: 01/08/2006 Age: Possibly Wise Posts: 493 Rally Car: Dreaming of escorts and xrats |
