Re: Skid plate material - 5052 vs 6061
May 17, 2013 05:11PM
So, if we were to add some ridges running front to rear, should they just be small square, u-channel, or angle laid to make a V?
Is the welding of the material negate the benefit of added rigidity?
Can either material be bent with a sheet metal brake?
Edited 1 time(s). Last edit at 05/17/2013 05:12PM by NoCoast.
May 17, 2013 05:18PM
I dunno about all this talk of welding on a skidplate.
Not all cars are created equal.
Here's one from Subaru S12 World Car
Yes, and I bet that is a whole lot lighter and a whole lot more expensive then the one pictured above. But club level guys have to make their skidplate and their car last for a whole lot more than one or two events so compromises are acceptable. Different horses for different courses as they say.
That was just an example for welds on skid plates. I for example have 2 strips welded longitudinal for added stiffness. Some people add sidewalls others do other things, it just depends on the need.
Project328is
Arno Guerin
Volvo 242
May 17, 2013 05:45PM
Dave, Are you building me something similar for the Volvo? Can't wait to see it.... When can I stop by your shop and check out the progress?
Arno
"Sideways get you there Faster"
Edited 1 time(s). Last edit at 05/17/2013 05:45PM by Project328is.
