Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
Re: Car pulls to right under heavy breaking
June 09, 2013 06:50AM
My car pullled one direction on braking and the opposite on accel. The disconnected shocktower may have had something to do with this.
If everything else passes diagnostics, it could just be a big ol airbubble in the LF line.
Jay Woodward
Snohomish, WA
Chronologically, 46...
johnhuebbe
John Huebbe
1970 VW Beetle & 1991 Subaru Legacy
June 11, 2013 09:43PM
I took off the front calipers on both sides. The left side seems ok. The right side has uneven pad wear front to back.
Might be hard to tell from this photo:
I'll need to investigate more, but could this indicate one/two of the pistons sticking?
I looked over all the front suspension and couldn't find anything bent/broken. I'm going to check brake line pressure next and bleed the brakes.
Iowa999
no-one of consequence
June 11, 2013 09:50PM
Looks exactly like a sticky piston.
Creech
Scott Creech
Audi 90 Quattro (WIP)
June 11, 2013 10:08PM
Cannot see any piktarz, but description indicates sticking piston/slider/pin.
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Iowa999
June 11, 2013 11:58PM
[deleted] stupid
Edited 1 time(s). Last edit at 06/11/2013 11:59PM by Iowa999.
June 12, 2013 12:39AM
Ah, the old 3.5 piston calipers...
Creech
Scott Creech
June 12, 2013 12:52PM
Iowa999
[deleted] stupid
Finally saw picz. You wuz gonna correct me about the fixed 4-piston caliper, wadn't ya! tongue sticking out smiley
S'all good. Opinion I gave was "Genericized" to cover all types, but still adress th' prollem.....
(I don' a-need-a no steenkeen peechurz!)
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Iowa999
June 12, 2013 01:21PM
Creech
Exactly. Well done, sir. It was a snotty post about the lack of sliders on a 4-pot.
fliz
Chad Eixenberger
1988 VW Golf #687
June 13, 2013 08:24AM
Seems like if it's pulling right under braking, that the right side has more braking force, so the issue would be with the left side brakes.
And I've had more uneven wear than that on a street car.
June 14, 2013 03:33PM
Gentlemen, pad taper on the right caliper will mean a longer pedal causing a delayed reaction on the right, so it might not be the caliper problem. Sounds more like a worn control arm bush. Not sure how those are but its either the rear bush on the control arm or if its like the Ford its the bush where the torsion bar mounts to the control arm. It will cause toe out under braking and steer you to a different dimension of not cool.
PS: you can check if you have a collapsed line by pressing the pads in by hand.
johnhuebbe
John Huebbe
June 14, 2013 03:51PM
I've got both sides disassembled, so I'll check Bushings and BJs tonight.
June 14, 2013 05:01PM
What he's saying is if the hose is soggy, when you step on pedal it boings out, brakes are applied cuase its LOTS of pressure, but when they're shot as soon as you lift the foot, the hose collapses inside and presuure can't bleed off at the master cause its trapped in the system downstream--caliper side---of the blocked hose.
That was a chronic thing when I first started working full time on Saabs when they were all 9-15 years old...Federal law mandates the hose have its production date on them and they were ALL original hoses...
Glad Paulinho agrees with my gut feeling of a bush being dead or sumpin bent.
johnhuebbe
John Huebbe
June 14, 2013 11:10PM
Right side upper and lower ball joints were a bit worn. Nothing super excessive, but I'm replacing them. (left side felt like new) Also, the right side lower torsion arm bushing was worn. Replacing that too. The torsion arms are in good condition (nothing bent) and the bearings on the spindle are good.
As for the bushing, I cleaned out all of the old grease and this is what I found:
Once I get everything back together I'll let you know if this solved the problem.
June 14, 2013 11:47PM
Wow, that kinda looks like something in an old navy training film......
Creech
Scott Creech
June 15, 2013 12:36AM
Gonorrhea and YOU......
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
