Max
1983 MKI GTI
Rebuild
June 29, 2013 12:00PM
on how to get the front support out without messing it up. I unbolted the fenders/front where i can see. But both are glued in like they were preparing for an a-bomb. Not worried about the drivers fender. Its rusted out at the bottom. Id like to keep from destroying the inner well/horn on the drivers for sake of reusing on the rally car.
Edited 2 time(s). Last edit at 07/09/2013 11:53AM by Racinkid13.
Re: Need some tips...
June 29, 2013 12:52PM
Keep in mind I do work on Euro trash but, most core supports of that vintage are spot welded in so a spot drill and hammer/chisel may be your friend. The new VW stuff does have a bolt in core support tho, kinda neat. I'd try to con Sean or Robert into looking at stuff before you get too carried away, both the donor and rally car. Maybe lunch or beer or both...
darkknight9
Kirk Coughlin
Dreaming of escorts and xrats
June 29, 2013 12:54PM
THAT is good stuff!
Kirk Coughlin
Max
1983 MKI GTI
June 29, 2013 01:30PM
Ok, thanks Gene. I was wonder if they did. Ill keep scraping away and see if i can find the spot welds. I thought the whole car was held together with this stuff till i found bolts hidden under it.
Max
1983 MKI GTI
June 29, 2013 09:03PM
spent some time with the car and truck/chain and a good pine.
location of a-arm bushing on drivers side
location on passenger
trans mount
July 01, 2013 11:05PM
That looks like Mk2 Golf. Front support should just be bolted in, two bolts each side, with rubber bumpers.
July 02, 2013 12:04AM
Any reason you wouldn't want to turn the core support into a removable affair?
July 02, 2013 01:06AM
Nice cars like the mighty Saab 96 always came that way. Hood off in 2 seconds, whole front sheet in 2-3 more, radiator in less than 5,..
All cars should be so nice.
July 02, 2013 01:32AM
the audi guys do it on the 4k's fairly frequently.... maybe mr Bares might share a pic or two?
Edited 2 time(s). Last edit at 07/02/2013 01:36AM by aj_johnson.
July 04, 2013 02:03AM
Oh, nevermind. I looked at it again with my head turned sideways. Definitely a Mk1 Rabbit. As far as I know those front members are welded in on all of them. Bleah.
Max
1983 MKI GTI
July 07, 2013 08:03PM
July 07, 2013 08:12PM
Max, have you bought a handful of drill bits yet..
That is what you will be doing.. Its already early July...
July 07, 2013 08:28PM
spot weld drill bit will be your friend, pull the motor and trans and check the firewall for damage, extend the cage out to the strut towers, plate the strut towers.
July 07, 2013 08:30PM
Max, have you bought a truckload of drill bits yet..
FTFY. Ugh, I hate the look of crumpled metal.
I do wonder if you'd be better off getting it on a frame machine or at least a big ol' I-beam and a couple Hazard Fraught Tool Port-a-Powers, getting it "close enough" and plating over the de-crinkled bits. But I'm a moe-ron who thinks on a LeMons budget.
Max
1983 MKI GTI
July 07, 2013 09:15PM
talked with a couple folks. after I do what Tom mentioned, Im gonna take it to a frame shop and just tell them to get it close. then see where i need to splice in.
I cant seem to find spot weld bits. Home depot, lowes, Harbor freight. Everytime I can go by tool town its closed.
Ive got the donor beam, ive just got to get in in the car.
Also the skid plate is mangled. thatll be an interesting bit of fun.
