vbares
Vittorio Bares
Audi 4k (3b conversion)
Re: First JVAB Soooper Bitchin 50mm Struts ready to ship
July 26, 2007 02:12PM
Man!!
That's exactly what I was thinking of. I can't imagine they are that difficult to build. I've been designing it in my head, but if they're already done...
How much thread goes into the contol arm and how much adjustability do you have?
I'd like 6 of those as soon as possible! Are they in the mail yet winking smiley
Seriously, do you have a contact at 034 I could speak to?
owdlvr
Dave Hord
Audi 90q project car
July 26, 2007 02:34PM
The re-design by 034 Motorsports is even better, for sure.
On mine there is approx 2" of thread for each rod-end. I'd have to actually measure one to be sure, but I'm not living at home this week (up in Whistler for Crankworx).
Set-up on my car, with the OE ball joint at about halfway through it's adjustability, and the rod ends about 2 threads from bottoming out, I can EASILY get 3deg negative camber out of the arms. Raised up I have no doubt I can get enough negative camber out of them.
034 has been slow to release these, it's not on the top of their development list (take a look at the rest of their product line and you'll see they are quite busy!).
Send an email to nate@034motorsport.com and tell him that Dave Hord told you about the arms. Ask him to add you to a contact list of when these will be available. He may have an ETA, but he's more likely to say "we'll let you know when these are released".
-Dave
I'm not scared of commitment...I'm scared of you.
vbares
Vittorio Bares
July 27, 2007 10:14AM
Sent an email to Nate - thanks, awaiting response. I have seen how many new products they have - as well as OEM stuff!
BTW - what size tubing was used on yours and do you know if they'll be using the same size?
Ty Ty
Tyler Semple
2000 Jeep Cherokee Rallycrosser/89' Audi 90q Rallycrosser and stage car in progress...
July 31, 2007 05:29PM
John. I am interested in a set of these for my 90q. Could you shoot me an e-mail so we can discuss how much they'll cost and whatnot?
ty2000@maine.rr.com
July 31, 2007 06:05PM
> ty2000@ma&
> #105;ne.rr.co
> m
Email sent.
vbares
Vittorio Bares
August 07, 2007 08:29AM
Hey JVL - how we doing on those top mounts?
I've got adjustable lower control arms coming soon - so will need these to measure fit.
August 07, 2007 11:11AM
Got a note a couple of days ago the money was in the guy's account so it should be winging its way directly to you.
I'll send a note to ask status directly to the guy.
Hey! you never sent any photos of the stuff mounted up!
vbares
Vittorio Bares
August 07, 2007 11:46AM
Cool deal!
I got the design from Dave Hord, spoke to the guys at 034 (as Dave's was the prototype) - they said to go ahead and have them built if I'd like - but some super bitchin' lower a-arms are in the works.
When I get the whole deal put together I'll post pics !
I think that's when the SB suspenders will shine as they should...
acrane
adam crane
corolla GT-yes
August 07, 2007 02:26PM
this weekend playing in the shit and jumping at the worker sprints, was the most extreme usage the plain 'old bitchin suspenders have ever gotten.
35 full cycles "bump stop to top" or so per 1:30run, time 5 runs with 3min cool down,
then the afternoon, with another 5 runs, then 9 fun runs, back to back.
The stuff held up fine, but got hot enough to burn my fingers.
now i see why they put heat sinks on desert racers.
makes me want to get the reservoir shocks for the rear.
at the sprints, an eclipse's rear shocks lost valving, front OLD DMS's got their final nail,
and the replacement rear KYB g2 shocks? less than one run.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
vbares
Vittorio Bares
August 18, 2007 10:32AM
Hey Dave (et al):
I had a thought on the design you've got there for the lower control arms. With the hime joints going directly to the sub-frame - I'm a bit worried that there's absolutely no pliability there. Good for response time, but not so sure I won't be bending arms like crazy?
Spoke to the guys at quattromotion - they agreed and also mentioned that Audi Sport also retained the bushings but used some type of track arm mechanism. Also on their (if you guys remember it) Audi Fox'enstein, they built the control arms by mounting a plate on the stock arms and the ball joint directly to that plate (using '91 coupe ball joints). Waiting on the pictures.
any thoughts?
CharlieV
August 18, 2007 10:55AM
Number 9 thru 11
http://www.mat.fi/project1983audiouattroa2.htm
August 18, 2007 10:56AM
vbares Wrote:
> Hey Dave (et al):
Vittorio, you get those top mounts from Sweden yet??
I haven't heard back from the guy, or you.
As for using rod ends inboard the only thing I'd worry about is if, or when they develop sloppiness.
If they're fine then no problem, if there's slack then there's a big spike in the shock load as the slop is taken up.
There are these nice 3/4" ends which are like rod ends except they are polyurethane.
http://www.deucefactory.com/ProductImages/parts/3293.GIF
How do you change a GIF to JPG?
That would be a good solution I think.
> arms like crazy?
> any thoughts?
Edited 2 time(s). Last edit at 08/18/2007 10:58AM by john vanlandingham.
owdlvr
Dave Hord
August 18, 2007 12:31PM
> arms like crazy?
I haven't bent any arms...but I've hit stuff hard enough to bend the shaft on a Bilstein, flat spot a wheel and tear the sidewall on two snow tires.
My control arms, and somewhat surprisingly the subframe, are all still straight.
-Dave
vbares
Vittorio Bares
August 19, 2007 08:42AM
Thanks Charles !!
In pic #17 its clear that busings were used. Also, I now have a very clear idea as to how the track arms work...
Very cool
vbares
Vittorio Bares
August 20, 2007 07:10AM
Hey John:
No news on the top mounts - haven't heard hide-nor-hair...
V-
