Since this seems hard for some to grasp.. RA build template.
Posted by alosix
alosix
Jason Powers
Re: Since this seems hard for some to grasp.. RA build template.
November 13, 2013 01:39PM
Don't you want to spec wire size, heat, and speed for the thicker material anyhow so the 1/8" or thicker plate being the concern.
Yeah, cars are surprisingly thin.
Yeah.. no doubt, but that's still within the range of .024. If I was just playing with the body panels (stitching) I really wouldn't question it and just throw my little .024 roll in for that.
Mostly just wondering if anyone had a favorite between the two for the round bits and the floor plates.
This isn't floor mat anarchy
alosix
Jason Powers
January 02, 2014 03:03PM
Good point Grant. The MM175 charts don't really show much for the 'good ranges' for each wire. After a bit of hunting through a few other books it seems this stuff is right at the higher end of .030's normal work range. (Damn Jeeper used to building stuff out of 3/16" or better winking smiley ).
In other news.. finally got the real 1/2 lats bent up and one of the notched and tacked in place. Used a combination of Grant's method and the starter template from bend-tech for the notch.
