Opinions on Map Lights?
Posted by RDR
fliz
Chad Eixenberger
1988 VW Golf #687
Re: Opinions on Map Lights?
August 30, 2013 10:12AM
Chevy Blazer third brake light. Its an array of red LED lights, quite bright, and already set up for 12v. You could cut it in half, cut a slot into some rollcage padding and have two don barrows lights for $10. A dimmer is recommended to set the light level.
Hey, I could just use the third brake light that came on the Golf. I'm pretty sure it was LED too, and it's definitely not going back in the hatch.
August 30, 2013 12:03PM
fliz
Why don't you just turn the lights on in your garage? spinning smiley sticking its tongue out
imnotcrazy
Don Kennedy
Impreza
August 30, 2013 12:22PM
The current car I'm competing in has the map light mounted to the transmission tunnel so it swings up, through my arm, and points away from the driver. One of the best flex mounts I've had.
FWIW, that's how our Hella is mounted. Works fine.
Don Kennedy
fliz
Chad Eixenberger
1988 VW Golf #687
August 30, 2013 01:28PM
fliz
Because I'm never out there. :p
Actually looks like it's a row of incandescent bulbs, with a red lens.
Dante
Allan Dantes
87 Mazda LSRX-7
August 30, 2013 01:52PM
Low blow Carl.
Either of you gonna be racing in October?
Owner, Driver, Head Mechanic, and Janitor at Tower City Race Team, headquartered near L'Anse. Michigan.
Driver / CoDriver in Rally America, NASARallySport, ARA, AMS, UPMDA, Champ Off Road
https://www.facebook.com/TowerCityRaceTeam/
https://www.instagram.com/towercityraceteam/
August 30, 2013 04:04PM
Dante
Low blow Carl.
There's a race in October? Oh yeah, the Central Div Regional Chumpionships are at Road America that weekend. We'll see how next weekend goes before we commit to it though.
August 30, 2013 07:01PM
Dante
Low blow Carl.
I'm reprepping the honda right now like I'm entering. Gotta sell some volvo stuff to help pay for the entry though.
Dante
Allan Dantes
87 Mazda LSRX-7
August 31, 2013 10:41AM
As far as map lights... I have the flexible, tunnel mount fancy one. White light and has never bothered me driving.
This last weekend at Ojibwe it failed...4 minutes before the start of the first real night stage.
I panicked. Codriver improvised quickly, and we ziptied his head lamp to the windshield bar with red light. Worked awesome! Some would say better than most.
I don't know WHAT we would have done if he hadn't brought the headlamp.
Rally on!
August 31, 2013 10:58AM
I really like a head lamp mounted to the visor of my helmet. The Tikka gives different intensity levels and red or white light. The batteries easily last for longer than the event. The best part is that the light is always with you.
August 31, 2013 11:56AM
Dante
Rally on!
I've tried--in vain---to convince people to have a fuse in an instantly reachable place--MARKED for the odo and Map light--separate!---and spare fuse and spare bulb taped with low tack tape to some instantly reachable spot--tape folded uner at one end do its a convenient tab to just pull..
What was the failure, do you know?
August 31, 2013 12:48PM
I usually have a headlamp around my neck for night stages, just in case the map light fails on stage or in case we have to deal with a problem with the car at some point.
I'd advocate breakers for map light and odo, but I really haven't had fuse issues with either. Often, I've found that replacing a blown fuse results in another blown fuse shortly after.
Still, having clearly marked breakers or fuses and having spares - of all the fuses - in the car, and accessible, is definitely a good idea.
August 31, 2013 11:16PM
If a fuse blows there is another problem.
September 01, 2013 01:27AM
That IS whi I use breakers. But some use fuses...
Greg Donovan
Greg Donovan
95 Impreza Sedan
September 01, 2013 10:07AM
What type of breaker do you advise be used?
September 01, 2013 12:14PM
Greg Donovan
Small, inexpensive ones. The ones i got I got back in the early 1980s from the beloved and long lamented Boeing surplus..for pennies.
Ya know, this is YET another area that there's a coolio idea and then ya get a buncha galoots saying (prancing and mincing it up like this: but say OOOh well I use circuit breakers dontch know OoooooOOOO!"
So a guy could get these for $4 each
http://www.waytekwire.com/wps/portal/en/products?pSearch=circuit%20breaker&psType=P&pg=8
But if you think of it this is yet another area to piss away $40-60 for what the miserable old fuse does...and an increase in price of well orders of magnitude. One trip to the junk yard and you can fill a shoe box with fuses for nuthin...
But, circuit breakers are cooooool..
And gotta say it:
In before "If you can't afford $60 for circuit breakers, you can't afford to rally."
