fliz Chad Eixenberger Professional Moderator Location: Grafton, WI Join Date: 02/01/2007 Age: Midlife Crisis Posts: 484 Rally Car: 1988 VW Golf #687 |
Hey, I could just use the third brake light that came on the Golf. I'm pretty sure it was LED too, and it's definitely not going back in the hatch. |
Carl S Carl Seidel Professional Moderator Location: Fe Mtn, MI Join Date: 02/10/2006 Age: Midlife Crisis Posts: 765 Rally Car: 1993 honderp |
Why don't you just turn the lights on in your garage? ![]() |
imnotcrazy Don Kennedy Infallible Moderator Location: Reading, PA Join Date: 10/05/2006 Age: Fossilized Posts: 227 Rally Car: Impreza |
FWIW, that's how our Hella is mounted. Works fine. Don Kennedy |
Because I'm never out there. :p Actually looks like it's a row of incandescent bulbs, with a red lens. |
Dante Allan Dantes Junior Moderator Location: Herman, MI Join Date: 01/27/2006 Age: Midlife Crisis Posts: 176 Rally Car: 87 Mazda LSRX-7 |
Low blow Carl.
Either of you gonna be racing in October? Owner, Driver, Head Mechanic, and Janitor at Tower City Race Team, headquartered near L'Anse. Michigan. Driver / CoDriver in Rally America, NASARallySport, ARA, AMS, UPMDA, Champ Off Road https://www.facebook.com/TowerCityRaceTeam/ https://www.instagram.com/towercityraceteam/ |
As far as map lights... I have the flexible, tunnel mount fancy one. White light and has never bothered me driving.
This last weekend at Ojibwe it failed...4 minutes before the start of the first real night stage. I panicked. Codriver improvised quickly, and we ziptied his head lamp to the windshield bar with red light. Worked awesome! Some would say better than most. I don't know WHAT we would have done if he hadn't brought the headlamp. Rally on! Owner, Driver, Head Mechanic, and Janitor at Tower City Race Team, headquartered near L'Anse. Michigan. Driver / CoDriver in Rally America, NASARallySport, ARA, AMS, UPMDA, Champ Off Road https://www.facebook.com/TowerCityRaceTeam/ https://www.instagram.com/towercityraceteam/ |
Rallymech Robert Gobright Super Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Possibly Wise Posts: 1,292 Rally Car: 91 VW GTI 8V |
I really like a head lamp mounted to the visor of my helmet. The Tikka gives different intensity levels and red or white light. The batteries easily last for longer than the event. The best part is that the light is always with you.
I've tried--in vain---to convince people to have a fuse in an instantly reachable place--MARKED for the odo and Map light--separate!---and spare fuse and spare bulb taped with low tack tape to some instantly reachable spot--tape folded uner at one end do its a convenient tab to just pull.. What was the failure, do you know? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I usually have a headlamp around my neck for night stages, just in case the map light fails on stage or in case we have to deal with a problem with the car at some point.
I'd advocate breakers for map light and odo, but I really haven't had fuse issues with either. Often, I've found that replacing a blown fuse results in another blown fuse shortly after. Still, having clearly marked breakers or fuses and having spares - of all the fuses - in the car, and accessible, is definitely a good idea. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
That IS whi I use breakers. But some use fuses... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Greg Donovan Greg Donovan Elite Moderator Location: Fargo, ND Join Date: 04/12/2007 Age: Possibly Wise Posts: 423 Rally Car: 95 Impreza Sedan |
Small, inexpensive ones. The ones i got I got back in the early 1980s from the beloved and long lamented Boeing surplus..for pennies. Ya know, this is YET another area that there's a coolio idea and then ya get a buncha galoots saying (prancing and mincing it up like this: but say OOOh well I use circuit breakers dontch know OoooooOOOO!" So a guy could get these for $4 each http://www.waytekwire.com/wps/portal/en/products?pSearch=circuit%20breaker&psType=P&pg=8 But if you think of it this is yet another area to piss away $40-60 for what the miserable old fuse does...and an increase in price of well orders of magnitude. One trip to the junk yard and you can fill a shoe box with fuses for nuthin... But, circuit breakers are cooooool.. And gotta say it: In before "If you can't afford $60 for circuit breakers, you can't afford to rally." John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
