Carl S Carl Seidel Senior Moderator Location: Fe Mtn, MI Join Date: 02/10/2006 Age: Midlife Crisis Posts: 765 Rally Car: 1993 honderp |
Here's what a serious high buck team starting with an S (or maybe a P I guess) did with their sump guard mounting: ![]() Kinda hard to tell from that drawring, but heres a picture of something close. http://farm4.static.flickr.com/3522/3189297171_914a92a6bd_b.jpg But you want a vertical leg going from where the skid plate mounts to that rusty tube going up to the frame rail. Triangulation and all that. I think this style is more easily replicated in someone's garage because you don't need a CNC laser, press brake, and aluminum welding capabilities. It may weigh a little bit more than the fancy aluminum ford piece, but can probably be built for a fraction of the price. |
Remember the rock on Gilhouly? Fawk it was like the car was doing a wheelie BAM!!!! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I was thinking of that one... come around the corner and theres a rock the size of a bowling ball right in line. 3/8 alum plate and underlying 1x2 steel frame earned its keep there. |
imnotcrazy Don Kennedy Mod Moderator Location: Reading, PA Join Date: 10/05/2006 Age: Fossilized Posts: 227 Rally Car: Impreza |
I have something similar to what John showed on my Impreza. Made of 1" square tubing, it goes across, comes up inside the frame rails and then out and bolts on to the rear bolt holding the bumper beam in place. Skid plate is mounted to radiator support, the above mentioned support and the small plate (jacking point?) on the cross member. Has worked well for me. Don Kennedy |
pdxphil42 Phil Meyers Junior Moderator Location: Portland, OR Join Date: 05/05/2011 Age: Possibly Wise Posts: 116 Rally Car: 1988 Mazda 323 GTX #214 |
I drill the mounting holes through the skid plate to be oversized and use a large fender washer on the bolt. Bent the crap out of a couple of plates from hitting large rocks but never bent the mounts that way. It has it's limits though.
"I, for one, welcome our Robot Overlords." - Philip J. Fry |
JohnLane John Lane Super Moderator Location: Lynden Washington Join Date: 01/14/2006 Age: Possibly Wise Posts: 725 Rally Car: The Fire Breathing Monster |
My skidplate is bolted in front via a pair of engine mounts for some give there.... In the rear of the plate on the rear of the front suspension cross-member it is bolted up with big fasteners and fender washers.
Big thick plate that was originally intended for a Scirocco. It has served well in the Volvo and taken some impressive hits. JohnLane Overkill is consistently more fun |
Frame from our VW
