Clayto
Clayton McCrary
XRatty purchased. Now build it!!
Re: Rear tubular suspension
September 14, 2013 11:06PM
Reamer
They make dom the perfect size for a 3/4" fine thread tap. I think it is the 120 wall but not positive on that. Either way if you buy the right size you just cut tap and rally. The swedge tubes JVL are talking about are super strong. I have broke a couple over the years. They brake at the swedge. They take major abuse thow. Ive never broke one just racing,more concrete walls and spins with a car hitting you at 70mph type brakes hits.
If you plan on running a rear swaybar you need to engineer a little more then just tubes. I guess you could figure within a turn and set the tow with the front tube.
As for the spacers. I made my first set back in 2000 out of 1" aluminum bar stock.I copied them from UB machine who must of copied them from JVLwinking smiley. I drilled the center to 1/2" then lathed down the end to 3/4" about 1/4" deep. then cut them off at the length I needed them to be.
The only thing ive run into with the bushings is if you take a big hit you will bend the bolts and knock out your toe. Hardened bolts bend to it just makes it tuffer to cut them out after there bent so use a softer bolt. The sheer strentgh of a 12mm bolt is super high but the do bend easier now that every thing is solid.
I would change out sway bar if a 4 link went in. That's a lotta weight gone with the stock pieces outsmiling smiley
Maybe set up some tabs on the front links for the sway bar if I ever need it.
Started writing down numbers to figure what types of tube or metal stock and found piercemotorsports.com
Jim Pierce from California sells a bolt and go set up online for RallyEscorts and Velosters and one other car...
Cool stuff but definitely heavy like JVL said.
Big chunks of aluminum to match the stock links would do fine,no?
September 14, 2013 11:09PM
Clayto
Que?
Clayto
Clayton McCrary
September 15, 2013 12:00AM
Clayto
Que?
As Tim said in the opening of the thread...
Ok, I've only got a handful of ongoing projects, lets throw another one on the pile.
Why would an escort need beefy stock arms anyway? Or even beefy DOM tube?
Why not replicate stock dimensions with aluminum block and bolt on?
Is that silly?
TronDD
Tim Meunier
96 Subaru Impreza
September 15, 2013 09:51AM
It doesn't need beefy tubes, that's why JVL said you don't need to go so far as .186 wall thickness.
I guess even .120 is big? That's what I don't know, I can work a power tool but I don't have the fab experience to know how strong anything is.
The easiest thing for me seems to be the swedged tubes and a few rod ends from summit. I still have the problem of reducers/spacers but I think I'll get a hold of the rod ends and see what I can do then.
Tim.
Clayto
Clayton McCrary
September 15, 2013 11:30AM
Good idea... Thecoleman racing site has nice tubes .....and a set of heims from phelps racing. All inexpensive enough to afford replacements
Might need a spacers rom JVL to fit the joint properly and keep anglessmiling smiley
Edited 1 time(s). Last edit at 09/15/2013 11:58AM by Clayto.
September 15, 2013 11:57AM
TronDD
Tim.
Guess you boys are getting the hint that if you all go measure your lengths I can do another run of the nice plug in things.
All the end things similar I've seen, aside from being inch, seem to miss one important thing: the chamfer on the flat face.. That chamfer is the key to happiness in service. When the joint has been in service a while when installing if the assembly is cocked over the chamfer doesn't catch the edge of where you're shoving it in and dig in and raise a burr----making it impossible to shove the thing in till you file the burr down.
Instead, the chamfer self aligns things and the arm slides in all sweet and easy..
TronDD
Tim Meunier
96 Subaru Impreza
September 15, 2013 01:46PM
Does it make sense that I only need spacers that are 9.255mm thick on each side?
Oo, Phelps has a nice package deal on ebay for all 8 ends. $105 and free shipping. Cheapest I have seen.
Tim.
September 15, 2013 03:05PM
TronDD
Tim.
Wha? we need the "width" or length of the bush--or better, a measure of the gap the assembly slides in between. Like 60mm or 45mm
Clayto
Clayton McCrary
September 15, 2013 03:14PM
TronDD
Tim.
Yea
Only way really is order a set then measure in hand....... I think I'll order some tonite.
TronDD
Tim Meunier
96 Subaru Impreza
September 15, 2013 03:25PM
Stock subie bushings are 40mm wide. I posted that yesterday.
40mm - 21.488 (.846in for the 3/4 rod ends) = 18.512 space left to fill / 2 = 9.255mm spacers on each side. Yes?
I also need to reduce from 3/4 to M12 on 4 ends, and to M14 on the other 4 ends.
Tim.
Reamer
Jeff Reamer
Subaru
September 15, 2013 04:25PM
You will need to do something about the holes on the sub frame ware the cam bolts were. Those holes are bigger then 12mm. Maybe weld washer in place.
First rally 2013
Rally car type AWD subaru
Total rallies as driver 6
Total rally cars built 2
Total rally cars caged 3
Like 31motorsports on FB!
TronDD
Tim Meunier
96 Subaru Impreza
September 15, 2013 05:00PM
Yup. It's only one side of one hole. Depending on how much deeper I want to go, I might pull the sub frame and double up the lateral link mounts. Scope creep...
Tim.
September 15, 2013 05:22PM
Clayto
TronDD
Tim.
Yea
We are not understanding each other...I suggest we resort to talking not typing. I don't know what you think you're gonna buy...
mke723
Mike Lindenfelser
1995 Impreza L
September 15, 2013 08:06PM
Reamer
you can either weld a washer on 2, or drill all sub frame mounts out to 14mm so you can order ALL your heims in 14mm (remember thats the size on the other end) i would imagine you could get a better deal ordering 8 of 1, rather than 4 and 4...
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to.
Clayto
Clayton McCrary
September 15, 2013 08:13PM
Clayto
TronDD
Tim.
Yea
Sorry for confusion in the conversation John
We mentioned some end links on eBay $105 for a set of 8-3/4" heim with lock
Seems like a good deal, no?
Need joints to get proper clearance dimensions?
