Yet Another Skidplate Mounting thread...
Posted by Aaron Luptak
MattP
Matt Pullen
2002 Ford StRanger
Re: Yet Another Skidplate Mounting thread...
November 09, 2013 12:50PM
I used to run works Kevlar sump and tank guards on my Seat Cupra in the late 90's early 00's so good and relatively light! They had a thick epoxy outer coating so didn't get chewed up so badly on gravel.
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
ryanfay
guess
1983 volvo 242tic
November 10, 2013 10:25PM
What do you rwd guys use to protect the snout on the diff or driveshaft?
November 10, 2013 11:34PM
ryanfay
Some guys make little skidplates, some are just brave.
November 11, 2013 07:44AM
ryanfay
Nothing. Been in about 80 rallies with no protection for either in a variety of RWD cars. Got one little dent in a driveshaft once but no bends. Front and rear control arms, and things like radius rods and cross members and exhaust systems, are what take the beatings.
November 11, 2013 12:51PM
ryanfay
ALL my friends but one were all RWD guys and back when we would go "playing' 2-3 times a month we'd do 150-180 miles a night. Nobody did a thing.
We dinged a few cases but the worse scars came from reverse back from wash-outs or dead ends where we couldn't turn around so we're backing maybe a little too fast WHAM (airborn) ..
Its like you said: things perpendicular to direction of travel or in clear THINGS STICKING OUT is what TENDS to suffer.
November 11, 2013 09:04PM
Fortunately never backed into anything..,,,but I am not dead yet so that possiblity is still there!
BTW, the OP mentioned bolt heads; I've had all sorts of bolts holding up skid plates. As long as they stay good and tight and flat & snug up against the bottom of the plate, all that happens is a bit of wear on the heads. On a rally like Maine (NEFR), they can get some good grind marks on them from the granite rocks.
If they get ground down a bit to where they might be hard to remove in a quick service, OR, more importantly, if they loosen or the heads get a bit cocked, THEN replace them. A loose or cocked bolt head is the only time you might have a problem shearing one off. Otherwise, don't take the time to recess them; a grade 5 or 8 and a good washer between them and the skid plate, a good tight fit, and you're good to go. It might be more of a problem a the Baja.....but we aren't doing the Baja.
Josh Wimpey
Josh Wimpey
Sneak the Golf
November 12, 2013 11:49AM
Not sure this is helpful but this is the only picture I have of our skidplate frame on the Golf
One. Class -- 2WD
www.quantumrallysport.com
