RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
Re: BAJABARU
November 05, 2013 04:04PM
Very cool project William!
Being an off roader(but currently Truckless/Jeepless)-I approve!
I'm also broke,but since I'm daydreaming here,my future daily driver would be this Impreza based critter, with your BAJABARU suspension shoved under it.
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
RALLYRS
Mike Ball
Re: BAJABARU
November 05, 2013 04:08PM
P.S.
How's the RWD Focus doing?
I posted up on one of the Focus forums for locals to contact you to discuss helping you if they want to see fruition.
Hopefully someone contacted you......I'm a couple states away or I would definitely be hanging out there.
Post up Here:
and here:
Re: BAJABARU
November 28, 2013 04:22PM
Jigged and reinforced a old frame for the fornt its ready to test fit im going to
space the motor mounts down 2 inches and that will give me 2 inches top and botom.
close to getting all of the car in rough form going to need two more shocks
wheels tires and ill have a roller.
RSF2000 is there i just yearded every wire out of the car aganst a friends advice
i have a hotrod turn signal kit and a offroad 16 circut wiring harness. I plan on
using a microsquirt I want to keep this motor stupid hell I with it had a dizzy
and carbs. If any one is fimilar with micros and would like to help set up for my
2.0 duratec I would really love some help. I also have 6 liqid filled gauges
simple stuff. This is my little intake its about ready its the cbr1000rr 44mm itb.
northcoast
Kevin Morrison
1998 Subaru Imp
Re: BAJABARU
March 03, 2014 11:15AM
Update? Looking forward to seeing this in person.
Tree18is
Daniel Serna
BMW 318i
Re: BAJABARU
March 07, 2014 01:06AM
awesome!!!
Re: BAJABARU
March 21, 2014 08:23PM
front upper a arms are 99% done need the other shock tab now i can weld the mounts too the
fornt frame and get it set up in the car and finish this front end off. All i need is steering and brake
mounts on the 4 knuckels and its ready to make a roller and do bumpers and skids.
they are bent so I can run the 10 inch shock mounted in the stock tower is 20" of travel enough??
Im really happy with the fronts they are 19" thats not that bad on the upper the rear is 16"
Re: BAJABARU
April 22, 2014 01:35AM
northcoast
Kevin Morrison
1998 Subaru Imp
Re: BAJABARU
April 22, 2014 09:10AM
Getting closer! Love the travel.
Re: BAJABARU
April 27, 2014 06:34PM
need a new rear top mount too lower the arm in static position. need a new trialing mount this
ones too high up and rubs i cant go up much yet. other than that the rear is close to getting
bottoned up. and those are stock ford focuse front calipers in the back and the front are
Toyota tundra!
Re: BAJABARU
May 08, 2014 06:07PM
rear full droop haha in love with my car now
Re: BAJABARU
June 06, 2014 05:46PM
Re: BAJABARU
June 06, 2014 06:26PM
Holy crap, that there is some track...will that fit on a car trailer (not tryin to jinx you btw)?
You must be making axle centers, will a stock Sube joint articulate enough or you got something really neat and wicked in mind?
Re: BAJABARU
June 08, 2014 06:48PM
Its fitted for toyota supra and 930 inner and ford expedition unner cv they do 45 degrees.
its not at bad as it looks because of how long the cv will be. The body of the car is deceving
it is 8 inches narrower than a trophy truck and 3 inches under a full sized prerunner its the size
of a big ranger baja kit.
Re: BAJABARU
July 22, 2014 04:04PM
Re: BAJABARU
July 27, 2014 07:29PM
