dirty_d
Brandon B
wabbit season
Parts sleuth! (unknown wheel hub)
November 05, 2013 01:11PM
Anybody know what this hub might be from at first glance?
I have 8 of these on a machine that we are rebuilding. They have a suspicious 5 bolt pattern. The machine will eventually be a bottle rinser that captures bottles in a set of gripper belts, flips em upside down, shoots water in em' and then uprights them again so mice and dust and poop will theoretically be removed from your bottle before the beer goes in it.
Of course the people who originally built this fine piece of machinery put a ridiculous markup on what looks like chevy parts bin bits so i am trying to source them elsewise.
Dims and piccys for your edification
Re: Parts sleuth! (unknown wheel hub)
November 05, 2013 01:14PM
Mid-80s GM fullsize FWD rear hubs?
Robert Culbertson
Out of this dumpster fire
November 05, 2013 01:56PM
Trailer hubs?
Creech
Scott Creech
Audi 90 Quattro (WIP)
November 05, 2013 05:16PM
If you cannot figure it out, just find something that is roughly that height from the mounting-flange and use that. You can surely drill/weld/grind to fit. You are already "re-engineering" it, buy something common and cheap. Buy spares.
2.26" = ~57mm: is not that Honda hub-bore size? (mem'ry here)
No, wait - Honda used 4 on 100mm. Duh.
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Edited 2 time(s). Last edit at 11/05/2013 05:21PM by Creech.
November 05, 2013 09:15PM
bknblk2
Tony Wood
83 Citation "Oskar"
November 06, 2013 07:34AM
Bingo Bango! That's the hub on the rear beam of the rally Citation. Out of a late 80s Pontiac 6000 STE (rear disks)
November 06, 2013 09:05AM
Has that thing been drenched in the beer you'll be bottling?
Is it good beer (yikes!)...??????
dirty_d
Brandon B
wabbit season
November 06, 2013 10:46AM
I explored the 80s gm route and it looks close enough that we can make it work if the hub to mount distance is roughly the same or we can add a spacer. The plate on my hub is rectangular not angled like all the gm stuff though so i'm still on the hunt for a direct fit.
I'm going to a truck equipment / trailer store here in a bit i'll report back!
the hubs are in the center of two rotating assemblies (4 on each end) way crazy overkill for what they're doing but we don't want to re-engineer the damn thing and we'd rather not rebuild 8 of these puppies so we're hoping to find a direct replacement.
Not to worry they're not in contact with the beer in any way smiling smiley
EDIT: looked up the citation on rock auto and holy smokes it looks like a direct match. going to autozone to measure em up to confirm
Edited 2 time(s). Last edit at 11/06/2013 11:08AM by dirty_d.
dirty_d
Brandon B
wabbit season
November 07, 2013 08:19AM
Well, the citation hub was too big. 4.5 bolt pattern and the wheel side is too big to fit into the recessed area where it mounts. What i actually have is 5 x 4.25.
but the mount-side bolt pattern was correct as well as the offset between the two surfaces.
I bought one of the mid 80's gm fwd hubs like the autozone link above and it's an exact fit on the wheel side, and the mounting distance is correct. We'd have to remake 4 stainless weldments to fit the mount side, which would be easier than modifyiing the 8 circles to fit the citation hub. still, we'd rather keep it "stock" if we can still find the exact fit hub.
I need to buy 8 of these puppies. The original machine manufacturer conveniently has them on the shelf for $470 a piece, which is laughable for what should be a 70 dollar part.
November 07, 2013 01:28PM
dirty_d
And they probably paid $20 a piece for 1000 of them back in 1987. smiling smiley
I remember Sean saying Car Quest usually has good dimensions in their dealer part catalogs.
Hit the pavement! Go find the oldest small car shop you can find and start asking around! I bet you could figure it out within a day.
tdrrally
edward mucklow
November 07, 2013 04:42PM
ford taurus rear hubs?
bknblk2
Tony Wood
83 Citation "Oskar"
November 08, 2013 08:34AM
The Pontiac hubs on Oskar are 5 X 114.7 and rectangular, not trapezoidal.
November 11, 2013 06:00PM
Fords use 5x108 (4.25) I would look at some of those. Taurus ect
dirty_d
Brandon B
wabbit season
November 18, 2013 11:48AM
found em' thanks to the nice folks @ Napa.
SKF BR930016
http://www.rockauto.com/catalog/moreinfo.php?pk=1835678
Thanks for your helps.
November 18, 2013 12:07PM
dirty_d
SKF BR930016
Well, what was it for application?
