Supra Diff in Xratty - breakaway torque
Posted by jbass
Re: Supra Diff in Xratty - breakaway torque
February 01, 2014 12:57AM
I will chime in. Take the diff apart and stack the frictios correctly, and run the 250lb kit. I was super agro at first, but after it broke in it settled down, and is perfectly fine in normal driving.
Never broke a cv, and never used anything but good OEM ones. Avoid the "New" ones like the plague. Loose stock ones are better. Clean them up and put a new boot on them .
4.3 with rally tires seems perfect to me..
February 01, 2014 10:39AM
Sean you 'member which side is longer? Pass or driver?
Robert Culbertson
Out of this dumpster fire
April 20, 2015 05:43PM
Bumping this back up.
Does anyone know the plunge in the CVs when it is the least (near horizontal) and greatest (full droop)?
I'd like to add a locating ring to the inboard side of the CV converters, and then drill out the holes slightly for added clearance. I could also just drill out the mounting holes slightly so the studs pass right on through without any drama (more chances of wobbly CVs though).
Reason for all of this: They suck to remove unless you have hammer and a pry bar.
April 20, 2015 06:36PM
Robert Culbertson
Somehow everybody elese worldwide can live without this..
The Supra diff is 40mm narrower than the Ford diff, thus the spacers are 20mm each and things are just like normal..
Look into something else.. Like 2 long side ones or something..
(shaking head---always having to fuck with stuff that others don't have to... Is that why your shit is never done"winking smiley
Robert Culbertson
April 20, 2015 06:56PM
Thanks John. I'm just trying to make it so removal of the adapters doesn't involve a hammer and a pry bar as stated above.
April 20, 2015 11:34PM
Robert Culbertson
What the fuck are you removing the adaptors for?
They were intended to go on and stay on.eye rolling smiley
Removing the half shaft? Pull the normal bolts.
Robert Culbertson
April 21, 2015 12:13AM
Swapping the diff, the old supra diff was not too happy. Every bearing was pitted and/or grooved, and there was about zero clutch material left on the plates. Large burrs on the tops of every tooth as well, enough to cut a nitrile glove.
April 21, 2015 12:39AM
Robert Culbertson
Then you are changing nit in the garage or shop...and you cook up some brilliant plan to make a locating ring --dill out this and fuck around..because you don't have a pry bar and a hammer...
in the garage/shop...
And no suitable substitutes like an old screw driver and a brick...
eye rolling smiley
Anybody ever check for any oil in the thing?
