NEWB with a half built shell! HELP!
Posted by Dmc
Re: NEWB with a half built shell! HELP!
February 18, 2014 12:52PM
imnotcrazy
What the heck is the bitch bolt?
I'm guessing the 28" long one that sticks through the full hub and both trailing arms that is always seized and a bit of a bitch to get out?
I used a hub tamer on car bearing tool so didn't have to mess with that, alignments, or presses...
czwalga
steve czwalga
95 awd celica
February 18, 2014 07:28PM
Does the hub turn without the wheels? This confuses me why put the hub/wheels on the car after pressing the bearing and not being able to rotate it the hub. If the hub rotates fine off the car, its most likely something binding with you rotor/brakes.
If the hub doesnt rotate free off the car, well you pressed it in wrong, or broke something taking it out. Did you support the inner race pressing the hub in?
Edited 1 time(s). Last edit at 02/18/2014 07:30PM by czwalga.
Creech
Scott Creech
Audi 90 Quattro (WIP)
February 18, 2014 07:49PM
Are those the bearings that are sealed and don't require repacking with grease nor the use of the dust seals? I know on Amazon it lists them as "Rear Wheel Bearing - Sealed"
I know I did a set on an 01 Outback for a friend and the bearings he bought were a one piece sealed design. Perhaps you are duplicating a seal and crushing stuff?
Since you've already torqued it to 160 I'd take the halfshaft back out and visually inspect where it is crushing.
This. I have done this once (not on a Scoobie, but still....)
You eventually get over feeling Stupid.
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Dmc
Duncan McPhedran
Impretzle two and one half
Dmc
February 18, 2014 07:57PM
czwalga
The hub does turn, until the axle nut is torqued. I'm thinking it may be the dust seal in backwards.
I pulled it all the way apart, got rid of some extra grease, and put it back together. It was a little better, but still waaaaayy too hard...
Dmc
Duncan McPhedran
Dmc
February 18, 2014 07:59PM
I'm lucky enough to have access to a hub tamer, press, and alignment machine... Now if I could get them to play nice.
Dmc
Duncan McPhedran
Dmc
February 19, 2014 11:49PM
Ok!
Turns out that the dust seal was binding on the axle. On one side it got really chewed up, which is what gave it away. New plan is no dust seals and constant vigilance.
Thanks for all the help and hints!
