Wheel studs...
Posted by gvb
gvb
Gaylord Van Brocklin
Mk2 Golf
gvb
Wheel studs...
April 22, 2014 01:57PM
Finally getting my new car together... Mk2 chassis running Mk3 5 lug, which I believe is M14x1.5.
Going to be running Team Dynamics wheels, which I think want 60 degree conical lugs.
Any recommendations on wheel studs/lugs? ARP doesn't make any M14.
Re: Wheel studs...
April 22, 2014 02:43PM
Did someone change them? I didn't think they'd used anything other than M12 since the 70s.
Did you buy Scott Leonard's car?
gvb
Mk2 Golf
gvb
Re: Wheel studs...
April 22, 2014 03:30PM
This is a new build... not Scott's old car.
It'll be Mk3 VR6 front hubs and Mk4 rear hubs. Both are 5x100 @ M14x1.5 based on everything I can find on the net.
Just found some stuff from H&R, but I question the "race strength" of them:
http://www.hrsprings.com/applications/quicksafe
Thanks!
Re: Wheel studs...
April 22, 2014 04:18PM
gvb
Thanks!
Ugh (groan)
Here:
Bugpack M14 x 1.5 x 2.2" long, chase the hole and press them in. Give them a little zap just for security
These are my default stud and I use them on everything I can get my hands on
like Modded Toyota 8" axle going in Volvo
And Volvo fronts, of course:
There are available open end nuts with either VW ball seat or normal taper seat.
Thank you.
Edited 1 time(s). Last edit at 04/22/2014 07:03PM by john vanlandingham.
modernbeat
Jason McDaniel
Re: Wheel studs...
April 22, 2014 06:37PM
I've been using MSI studs, though their nuts are too big for some wheels.
http://msiracingproducts.com/products.html
Don't get them too long so they don't get damaged.
Jason McDaniel
Robert Culbertson
Out of this dumpster fire
Re: Wheel studs...
April 22, 2014 06:48PM
There's a ARP Honda stud that's dirt cheap. The Bugpack 14mm are cheaper and a bit shorter, which is a good thing unless you're running huge spacers.
ARP Honda Studs, in a 5-pack!
Any press-in stud will require you to remove the front drive flange, and in the process you'll destroy the front wheel bearing. There are some nicer screw in types, but they may back out at some point.
Edited 1 time(s). Last edit at 04/22/2014 06:52PM by Robert Culbertson.
Re: Wheel studs...
April 22, 2014 07:02PM
modernbeat
What do those M14 thangs cost?
gvb
Mk2 Golf
gvb
Re: Wheel studs...
April 22, 2014 07:19PM
Thanks John! Profile updated.
Robert, nope... just checked. The ARP Honda studs you linked wouldn't work for the Mk3 VR6 or Mk4 stuff that uses larger M14 bolts anyway. Bugpack seems to be the way to go.
Now to see if these 14mm nuts will fit into the Team Dynamics wheels.
Edited 1 time(s). Last edit at 04/22/2014 07:32PM by gvb.
Robert Culbertson
Re: Wheel studs...
April 22, 2014 07:47PM
You are completely right on that! Apparently VR6 uses 14mm studs, I can learn new things!
I also found these while I was verifying that: http://store.blackforestindustries.com/blsppostm11.html
Also, I should be hitting the machine shop tomorrow to finish up your adapters to replace the set that USPS ate.
Re: Wheel studs...
April 22, 2014 11:29PM
modernbeat
2nded.
Found these: http://prosystembrakes.com/catalog/product_info.php?products_id=799
Bimmerworld also has thread-in wheel studs "Made by one of America's leading manufacturers of race fasteners" (Guessing MSI?) from $5-$15. Each.
Re: Wheel studs...
April 22, 2014 11:35PM
Also found while doing some digging...
http://forums.pelicanparts.com/porsche-911-technical-forum/651028-quick-start-wheel-stud.html
Especially with the bullet end, you are adding rotating, unsprung weight.
drinking smileyeye rolling smiley
That shit makes any of the pointless wanking that goes on here look like amateur hour.
Re: Wheel studs...
April 23, 2014 07:52AM
Wonder if it would be ruled somehow "Justifiable Homicide' if somebody strangled the guy who posted shit like there.
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: Wheel studs...
April 23, 2014 12:51PM
I have used these on 6 cars over the past 14 years with no complaints and never had one back out.
On street cars, I use the cheapo $139 studs
On rally cars, I get the nicer "race" studs for under $4
One. Class -- 2WD
www.quantumrallysport.com
Re: Wheel studs...
April 23, 2014 01:22PM
Josh Wimpey
Did you forget a link?
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: Wheel studs...
April 23, 2014 02:04PM
DOH
http://www.track-studs.com/catemp/
Josh Wimpey
One. Class -- 2WD
