gvb
Gaylord Van Brocklin
Mk2 Golf
gvb
Re: Wheel studs...
May 05, 2014 06:38PM
Bugpack M14 x 1.5 x 2.2" long, chase the hole and press them in. Give them a little zap just for security
These are my default stud and I use them on everything I can get my hands on
like Modded Toyota 8" axle going in Volvo
There are available open end nuts with either VW ball seat or normal taper seat.
Thank you.
John,
Where are you buying your Bugpack stuff from? They won't sell direct to me.
Also, I can only find lugs from Bugpack with ball seat.
Thanks!
Re: Wheel studs...
May 05, 2014 06:57PM
gvb
Thank you.
John,
Thanks!
I pop over to this VW place just the other side of Sea-Tac airport... I'm 2 miles N and they're 1 mile S..
Comes in 5 packs for like 10.50 w tax.
For normal taper:
http://www.ebay.com/itm/370613087402?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
his is a listing for a set of TWENTY (20)
Otis Inc LA European Made Lug Nuts
NO ASIAN PARTS HERE!
These open lug nuts are size 14mmx1.5, 60° Cone Seat, Hex 19, Total Length 17mm, Zinc
PART NUMBER B-D62
Check out my other listings for other sizes! If you do not see the size you are looking for please email, chances are we have it!
gvb
Mk2 Golf
gvb
Re: Wheel studs...
May 05, 2014 06:58PM
I ended up paying $14 for a 5 pack of the studs from a Bugpack reseller in CA.
The Track Studs that Josh linked has hardened steel lugs.. $28 for 20... went with those.
Thanks.
Edited 1 time(s). Last edit at 05/05/2014 07:02PM by gvb.
