Adjusting ride height on JVAB?
Posted by MattZig
MattZig
Matthew Breden
2002 Subaru Impreza TRX
June 21, 2014 05:08PM
Is there a way to adjust ride height on JVAB 50mm's? The rear is good but the front is sitting really high even after a couple rally's. It doesn't have an adjustable lower body, so the only thing I was thinking would be to play with the springs. I'm running a 275 in the front I'm pretty sure. If I went to a longer spring, would it compress more before settling compared to a shorter one?
MattP
Matt Pullen
2002 Ford StRanger
Re: Adjusting ride height on JVAB?
June 21, 2014 08:43PM
Matt, why don't you just call John and ask him. You can find his number on most threads here.
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
June 22, 2014 01:13PM
Manufacturing defect??cool smiley
June 22, 2014 02:15PM
Gene, gene, Gene,
Don'tca think that is a bit uncalled for?
Truth of the matter is that the JVAB suspenders aren't a bad strut an usually any fitment issues are 'first run' things that are 'made right.' I don't know if Matt bought these new from John, or if he sourced a used set, but the answer should be a quick phone call away to the JVAB intergalactic HQ.
In the mean time Matt:
Spring rates and lengths aren't really about ride height... depending on your source for the struts I'd either leave that alone - if bought new - or get them back to spec if sourced used.
I'd expect the struts to have a threaded body with adjustable spring perches... which is how you adjust ride height. (seems basic, but...) You'll want to be a bit careful and if at all possible corner weight your car to make sure the ride height is the same AND the balacne on the road is even. (if the car is tweaked, then putting the spring perches at the same 'height' on the strut body won't always give you a balanced stance.)
From your in-car I saw from Radium, you might be a bit stiff in the front-end, but you also have a LOT to learn about weight transfer... (the two can be related sometimes)
June 22, 2014 03:30PM
I'm sorry (head hanging in shame...smoking smiley )
Spring stiffness and height are two different hings. A taller spring wiht a 275 rating will just make your car even higher. A longer spring with a lighter rating say 175 might lower it. Anyway..honestly..don't be messing with it until John says so. He'll get it corrected a lot faster than messing about with guesswork.
June 23, 2014 07:43AM
Link to wrenches for adjusting ride height:
June 23, 2014 11:35AM
Forgot the link Grant.
Towona
Tony P
MK2 Golf
June 23, 2014 03:22PM
Or did he? tongue sticking out smiley
Runamuck Rally
Robert Culbertson
Out of this dumpster fire
June 23, 2014 04:29PM
Hammer and chisel/large-mangled-screwdriver
June 24, 2014 03:31PM
Shit. Thanks AJ!
http://bit.ly/1quBP9x
June 24, 2014 06:46PM
Yo homie in bro science we's cut da springs ta slam ar rides and git Sheniquah's ass back ova' heeah.
