Ford Focus ZX3 (Starting build!)
Posted by RileySteenFRT
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 10:33AM
So about six months ago I picked up a ZX3 with intentions of building a stage rally car. As of now I have it too where I could rally cross it but here is some progress!
My plans include a cage built by either Doug Davenport, or Whiskers.
JVAB Suspension (already in the works with a one off 50mm focus setup with Bilstein HD's! Cool!)
3,4,5 close ratio set and a different final drive
Already have a pretty rad motor. About 180whp tuned on 91 octane
May run a more aggressive cam with higher compression and puts for 195 just because
Seam weld everything of course
Sparco seating
Other then that I'm not sure what's going to happen!
I have some fab work ahead of me to get the JVAB in back
Also reinforcing arms and rear sub frame
Not sure on the focus front control arms as they are boxed and have to reinforce...
Rear is going to be tubular with forged aluminum adjustable Camber arms
All the rear control arms will be rhino lined or something along those lines
Roof venting, and I'm going to need change my intake setup as I don't want dust getting sucked up through my cold air intake... Ojibwe Forest and headwaters are very sand and dusty in places
And from what I understand,
Motors don't run well on dust fuel additive tongue sticking out smiley
Any information I can get is great, as well as lines on parts or other focus rallyists. I know O'reilly, and the juggernaut guys, Erik hill, as well as Few others.
open | download - image.jpg (37.9 KB)
imnotcrazy
Don Kennedy
Impreza
Re: Ford Focus ZX3 (Starting build!)
July 10, 2014 11:19AM
Before John beats on you. Update with real name and location.
Don Kennedy
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 11:27AM
John get in here and show yourself! Lol.
July 10, 2014 11:46AM
Welcome! I'd not bother with cracking into engine for the cam and higher compression until you've got three events or a blown engine. The 180 will be plenty and running on 91 instead of needing higher octane or converting to E85 will help with operating costs and getting onto stage!
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 11:56AM
Great point. MR Van Vurpa was turning me to the aggressive cam side
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 12:21PM
And realistically with my light weight car 180ish hp should pull itself just fine with proper gearing... No need to go overboard, even though I probably will.
July 10, 2014 12:34PM
imnotcrazy
He's a good kid. He understands..
Robert Culbertson
Out of this dumpster fire
July 10, 2014 12:46PM
DOHC Zetec engine?
Curious as to what it takes to get that to 180hp.
July 10, 2014 12:51PM
Robert Culbertson
DOHC Zetec engine?
Somebody spent some money.
More curious of course is what Foot-Lebz it makes
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 12:54PM
If I remember correctly it was around 167ft lbs?
open | download - image.jpg (42.1 KB)
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 12:57PM
167ftlbs I believe . I'll list mods in a bit
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
July 10, 2014 01:40PM
Welcome. That motor should scoot along pretty well even with the stock gear ratios.
Make sure to add reinforcement plates to the front strut tops as those tend to bend.
Seem welding outside of the front and rear suspension mounts is really not needed on these cars. But if you have the welder and the time go for it.
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 02:11PM
bought a plug and play welder a while back for sheet metal work I think itll do nicely. do you cut the tops and replace them or just reinforce them?
July 10, 2014 02:35PM
RileySteenFRT
Double them..maybe a touch thicker material..No need to go toooooooo crazy...If stock thickness lasts 200k miles then maybe 2-2.2 times stock will last a few years..
RileySteenFRT
Riley steen
Focus ZX3
July 10, 2014 03:50PM
just sheet metal then? say like 1/8 inch? wait this is rally... whats the metric conversion? how does 5mm sound...
