VW Mk2 control arm reinforcement
Posted by Mr. K
Mr. K
Chris Krepski
1991 VW Golf, 8V of fury!
July 16, 2014 10:41AM
Hi fellow VW Mk2 manglers and others,
We competed in Black Bear this past weekend. Everything was going very well until we went over an exposed rock on an uphill L4 and the left control arm was torn from its socket on the front mounting point, as seen in the photo. The roads were rougher than last year and it was raining in the morning, thus we were going over nasty stuff all day lol.
The control arms were new and were welded continuously around the perimeter, except for the front bushing socket. We used poly bushings also. The weld to the ring that retains the front bushing let go, out the control arm went, separating the CV joint from the driveshaft and the car just...stopped.
Has anyone else had a similar failure? Is this an area of the control arm we should reinforce (i.e. with an additional piece of sheet metal over the bushing socket) or leave as is, so as to have a failure point to prevent bending/breaking something else, such as the subframe or bodyshell?
Looking forward to your perspectives. Messrs. Burress, Hoche-Mong and Wimpey, what do you think?
Thanks,
Edited 2 time(s). Last edit at 07/16/2014 10:47AM by Mr. K.
open | download - control arm broke.jpg (51.4 KB)
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: VW Mk2 control arm reinforcement
July 16, 2014 12:36PM
Never seen that happen. Looks like the weld there broke and the clamshell just opened up. Cheap Chinese arms?
Maybe the urethane bushing did not fit tight enough and allowed some 'hammering'?
Anyway, no need for a urethane bushing up front, there is almost no movement there.
One. Class -- 2WD
www.quantumrallysport.com
DexterVW
David Baker
95 GTI TDI
July 16, 2014 12:52PM
Ive had this happen once .. about 50 miles into my commute on a brand spanking new 30 dollar chinese arm from a local "import" car parts laundry. I really should have expected it after the 45 dollar complete clutch kit let go in a fantastic fashion a few weeks earlier. But hey i was a college kid with a rust 16v gti... why pay more.
I'd say if you're worried about it wrap it.. but I'd try better arms first
Good luck
Mr. K
Chris Krepski
July 16, 2014 01:33PM
Thanks guys. They were new Febi control arms, not sure where they were made.
What's a good source for new higher quality arms if the Febis are no good? Just go to the dealer? Take the arms off the parts cars and clean 'em up?
Thanks,
Edited 1 time(s). Last edit at 07/16/2014 01:35PM by Mr. K.
July 16, 2014 02:03PM
I haven't seen that happen either.
I use OEM arms, reinforced. I usually just get 'em new and don't bother junkyard diving - they're cheap enough. I usually get them from germanautoparts.com.
July 16, 2014 02:40PM
Strengthen arm.
Strengthen crossmember
Strengthen shell
Easy.
Strengthen everything..
Oh Chris 8 50mm Bilsteins arrived but not your replacement of Kuligowski's
Grrrrrrrrrrrrrrrrrrrrrr
Mr. K
Chris Krepski
July 16, 2014 03:47PM
Based on my quick look online, it looks like Febi is what everyone is selling. I hope there are other choices...
Michel: do you remember which manufacturer made the arms you bought and about how long ago did you last buy a set?
John: Argh, frustrating. Hope that it arrives soon! Any luck straightening the bent one from Lanark?
I'm liking the idea of adding a small-gauge steel wrap around the front bushing socket. The main weld might break underneath, but the wrap would theoretically retain the bushing place so we can finish the stage.
fliz
Chad Eixenberger
1988 VW Golf #687
July 16, 2014 04:51PM
Are the Passat arms a different design at the front attachment?
Going wide-track might be an option.
July 16, 2014 04:55PM
Yes, Volkswagen. Yes, it was last year, about a week after I ripped off the whole right front corner at Mendocino.
DexterVW
David Baker
95 GTI TDI
July 16, 2014 04:56PM
Yes/No
So the Passat stuff bolts into your subframe all the same but needs Passat knuckle, which has slightly more material on it.. which "should" be stronger.
The down side is the passat stuff reduces your caster and puts the wheel about an inch farther back in the wheel well.
Going to the mk3 GTI VR6 "Plus" suspension fixes that issue and would be what I would do
here is the difference on my Mk3
Edited 1 time(s). Last edit at 07/16/2014 04:58PM by DexterVW.
Towona
Tony P
MK2 Golf
July 17, 2014 10:17AM
Try to source some good used oem arms from out west or down south (ie no rust).
We hit a boulder on that same side and it flipped the car. The wheel was pushed back a couple inches as the LCA folded. The mounting points were fine and we drove the car out of the stage.
Runamuck Rally
July 17, 2014 11:34AM
Towona
yep. I',m often appalled when I get peeps to send me piccies of under there car: monchrome.
100% rust colored.
Rust is insidious.. Don't know if most of the boys here know it but rust in a stressed area can give rise to crack propagation...and it can be down in the root of a weld or a joint---like in Saabs where there's a bar with the [ shaped arm arms poke thru...rust right there where the arm pokes thru---snap!
DexterVW
David Baker
95 GTI TDI
July 17, 2014 11:44AM
rust? whats that?
My Boston Beater... 44mpgs of rusty diesel smasher
Edited 1 time(s). Last edit at 07/17/2014 11:49AM by DexterVW.
Josh Wimpey
Josh Wimpey
Sneak the Golf
July 18, 2014 10:42AM
David, I am not sure why you are having trouble with the Passat arms. We have run several on two different cars and did not experience the offset issues you have.
DexterVW
Yes/No
One. Class -- 2WD
DexterVW
David Baker
95 GTI TDI
July 18, 2014 01:57PM
I wish I knew Josh... they came from a 92 Passat 16V and appear to be strait and true.
