The TDI is ALIVE !!!
Posted by Josh Wimpey
Josh Wimpey
Josh Wimpey
Sneak the Golf
July 19, 2014 12:18PM
The TDI is ALIVE!!!!!!
Still a bunch of work to go but it is technically drive-able, goes through all the gears, stops, starts, etc.
Thanks to Franz Diebold, Eric Langbein, US Rally Team, and New German Performance (NGP) for all the help over the past 6 years.
Even ran it through the gears (in the air)
See new brakes up front and the first pair of JVAB VW struts built (I think)
One. Class -- 2WD
www.quantumrallysport.com
Edited 1 time(s). Last edit at 07/19/2014 12:21PM by Josh Wimpey.
Re: The TDI is ALIVE !!!
July 19, 2014 02:43PM
Heh. The Quantum is the same color.
Back to gapping rings and Plastigauging bearings. I think I'll stick with rotaries from here on out.
Robert Culbertson
Out of this dumpster fire
July 20, 2014 09:54AM
Sweet! Nice brakes too!
Towona
Tony P
MK2 Golf
July 22, 2014 12:46PM
niiice
Runamuck Rally
July 22, 2014 01:47PM
Nice Josh! So, now you should give us some more specs.
ALH?
Turbo?
Nozzle?
Weight?
Let's get some serious drool fest going here!
It's pretty sad how much I enjoy my 2003 TDI Golf.
Josh Wimpey
Josh Wimpey
Sneak the Golf
July 22, 2014 02:26PM
ALH?
Turbo?
Nozzle?
Weight?
ALH? --- Yup 245,000 miles but we refreshed the head
Turbo? --- VNT17/22 care of NGP Racing
Nozzle? --- Still stock nozzles, injectors, injection pump, and tune
We are shooting for a mild setup with about 165hp and 300tq in order to keep smoke and EGTs down.
Weight? --- Unknown.
Gas car is 2340lbs ready to rally with fuel. The TDI is probably 40lbs more than the 16v accounting for the turbo, plumbing and intercooler. Trans is about 20lbs heavier too.
BUT:
TDI has a lighter skid plate & frame
TDI has a 13lb lighter front subframe
TDI has a 10lb HEAVIER battery
TDi has a more extensive cage but more 'right-sized' tubing 1" x 0.065" wall components
TDI has kevlar and resin underbody protection which adds weight
TDI has full glass windows and rubbers all around
TDI has 15" wheels & tires
So, I bet it is 2500lb right now but have not weighed it.
One. Class -- 2WD
July 22, 2014 02:40PM
Nice! Should be pretty attainable with that turbo, intercooler and exhaust, though maybe more nozzle needed.
Stoked to see some progress made on it!
Josh Wimpey
Josh Wimpey
Sneak the Golf
July 22, 2014 03:07PM
Definitely will do nozzles with the tune.
The turbo is capable of about 200hp max but that seems silly and requires a cam and revving higher than 5000rpm....
165 is pretty conservative but I want to never look at the gauges even if running WOT 90% of the time for 10-15 minutes straight like we do on many stages.
One. Class -- 2WD
July 22, 2014 03:56PM
And it'll be less likely to bend the rods. That becomes the next week point from what I've heard.
The worst thing (or best thing?) about turbo cars is you always want to do more. There are such gains that it makes it hard to leave them alone. NA cars once you do intake, nothing else really gains you much until you spend big. If I drive nice I can get 46 MPG on my TDI. I usually get 38 though cause I like acceleration.
Josh Wimpey
Josh Wimpey
Sneak the Golf
July 22, 2014 04:37PM
Should be in the mid 50's mpg-wise on transits based on the results of other mk2 conversions.
One. Class -- 2WD
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
July 22, 2014 05:38PM
Diesel will save rally!
sick car though.. smiling smiley
Josh Wimpey
Josh Wimpey
Sneak the Golf
August 21, 2014 09:34PM
Skid Plate frame with integrated lower radiator support and radiator/intercooler protection bar
One. Class -- 2WD
August 22, 2014 05:22PM
Coming nicely. When's the debut?
FYI: Did you know you have a left hand disc on the right side?
HiTempguy
2002 Subaru WRX STi
August 22, 2014 06:03PM
Besides (obviously) how awesome this is, any specific reason for going with the diesel? Just wondering if there is an advantage I am missing smiling smiley
Josh Wimpey
Josh Wimpey
Sneak the Golf
August 23, 2014 09:03AM
After recovering form building a garage
Yes
One. Class -- 2WD
