Mad Matt F
Edward,
The diff is standard duty Subie stuff from the 80's. (the car is an 88), I think the same casting as a few others (GL, Loyal etc), although not sure... There were a few ratios for the Justy, we have the earlier, better (less fuel efficient) 3.7, there was another ratio 3.4 or something with the constant variable transmission cars, and I think it also was used in the next generation for a lower cruising RPM.
The car is pretty fun, light (er well kinda) at about 1900lbs ready to race. has no brakes and no motor, so it's hard to screw up...
Matt
1900 LBS!!! HOLY SHIT!!!!! That much!!!???
With that leeeeeeetle tiiiiiiiiiiiny itsy bitsy motor???
My mighty V4 is way overbuilt from the stock 1945 lbs and weighs 2015lbs and had a rip snorting 1965cc motor with 11.3 comp and BIG 44.5mm intakes and bad ass cam...and 5.45 final drive
And relatively speaking, big brakes.
You need moar motorz! And moar gearingz.
