EricW Eric Wages Mega Moderator Location: Goose Creek, SC Join Date: 12/09/2008 Age: Midlife Crisis Posts: 280 Rally Car: 2002 WRX |
And, as I said, all of the injectors were sent away, tested, and cleaned. Results were that everything was a-okay before cleaning. |
It's what makes a subaru, a subaru. Grant Hughes |
Not trying to be argumentative, just wanting you to get to the bottom of this. I went through this once and found the 'smoking gun' problem which gave a positive indicator of what happened and what to fix.
Yeah, that looks pretty 'melty'....! Could be detonation but it does not look like a clear cut case of such; looks more like severe heating for some reason; could be detonation induced, could be other. No pitting anywhere that can accompany detonation. I like this discussion from a piston Mfr: http://www.kb-silvolite.com/features.php?action=read&F_id=46 Did you see any other similar damage or impending damage to the other pistons? How abou tthe plugs? All look the same or not? Some telltale dark spots on the pistons top side edges above the top grooves would probably (but not necessarily) have shown up if they were doing the same thing, which likely would be the case if it was the gas octane or contamination. If they are very different looking with no signs of any issues, I would wonder elsewhere than about the gas. As mentioned above by another, I have seen this type of damage from a large ignition advance. Can it be the gas? Yes, but it could also be other problems. Is this a standard O2 type sensor or what? If the AFR sensor got buggered and gave the wrong readings, the ECU would 'think' it was adjusting to the right AFR reading per the buggered sensor and would record perfectly good looking readings....but the real AFR would be wrong. And AFR being off due problems in one cylinder from some reason like a erratic injector or injector connector would throw the sensor off a bit and provide a partial adjustment to the problem but not enough to one correct cylinder that went way off. After this incident, I would certainly replace the sensor and that injector and check the connections reeeelly good. And BTW more humidity at RWV might be of help in a marginal case presuming it acted to lower combustion temps and combustion speed: afterall, H20 injection IS used for smoothing the burn and giving the effect of octane boost. The cooler air temp and lower elevation at BRS would give more air density and more O2 and leaner burn if the ECU did not adjust for that, but a proper working AFR sensor SHOULD help to compensate for that, as well as the temp sensor to the ECU. IS the ECU working with a temp sensor? The higher air density is probably not an issue.... just thinkin'.... |
Creech Scott Creech Super Moderator Location: Jane, MO Join Date: 12/02/2012 Age: Possibly Wise Posts: 415 Rally Car: Audi 90 Quattro (WIP) |
Heh. That looks familiar. Essentially everything in the crankcase covered in aluminium "splatter", I bet.... Parfois, on fait pas semblant! I am: I know: I am from: Nobody. Nothing. Nowhere. |
DaveK Dave Kern Mega Moderator Location: Centennial Join Date: 07/11/2008 Age: Midlife Crisis Posts: 1,085 Rally Car: Compact M3 & Evo IX |
Grants "it's what makes a Subaru a Subaru" comment made me recall a similar situation here in Colorado. Owner melted two motors during PPIHC week in very similar fashion. Turned out to be a bad fuel distribution block which was causing one cylinder to not get enough fuel. In his case injectors would've tested good.
I think I remember another subaru with issues related to the wiring harness under the intake manifold grounding out on something. Can't remember if it was misfire or boost related problems on that car though. Dave |
Do It Sidewayz Chris Martin Super Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
Knock did not cause this failure. Knock would have cracked the piston into pieces. You'd have broken ring lands, and there would be signs of detonation on the piston surface. All as someone else already mentioned. To melt a forged (i'm guessing) piston like this, something fundamentally is wrong. I do not believe the blame should be put on bad gas for this one, because if it was bad, all pistons would show signs (likely indication of detonation). When you say "AFR's were fine", please give us numbers. Are you sure that AFR's are ok at all running conditions? Is it ok at part throttle? "tip in"? high load/low rpm cells? What fuel rails are you using? OEM? OEM rails in series (oem fuel line routing)? OEM Rails in parallel? Chris Edited 2 time(s). Last edit at 01/16/2013 02:04PM by Do It Sidewayz. |
Usually a single oxygen sensor is located in a position where it picks up an average AFR reading for all the cylinders, so presumably this means that if there is a problem with just one cylinder for whatever reason, be it a valve, injector, spark plug, inlet manifold air leak etc, then could it not be masked to a significant extent by the good cylinders? Especially when there was obviously still some kind of combustion going on in the duff cylinder.
If none of the other pistons are showing any visible signs of anything untoward it must be isolated to that particular cylinder. Not on Subarus but I've seen a few brake servo pipe connections fail on inlet manifold runners in the past resulting in the cylinder that particular runner fed running lean. I also spend an extra few seconds making sure the wrist pin circlips have the gap at either the top or the bottom. Maybe that is only something to bother with in a 10,000rpm engine though. Disappointingly not yet a Jackass Edited 1 time(s). Last edit at 01/16/2013 01:16PM by danster. |
OK, tnx for patience with info. O2 sensor per se not the issue. Air temp sensor becomes critical for air density adjustments with the temp and humidty change of the RWV vs BRS case. MAP should take care of pressure altitude changes. Going from 40F dry from 80 F humid changes oxygen content by around 4-5% for unpressurized. I am not sure how this effects octane needed; shouldn't if proper fuel corrections are made for temp unless there is some off threshold effect of the final compressed air temp going on. Will do some reading as it is an interesting question. (to me) Temp sensor located where? Tested OK? Mapped into the ECU program for temp variations? Margins for more oxygen when cool and dry? Yeah, proably dumb questions, and probably already thought of by you long ago and in the programming; just checkin'. |
Wow, I bet that was not easy to find. |
Just ran across a graph of octane versus temp and relative humidiy to avoid detonation in "standard auto engines". The engine at 80F/80%RH needed < ON85. The same engine at 60F and 20% RH needed > ON88. (The ON change was approx another point bigger for 40F and low RH but the octane changes at lower temps get small.) Seems like a big ON change.
Not sure if this does anything for your situation, Eric, except to make sure there is margin in the ECU mapping to account for low temp, low humidty situations; otherwise the same xyz octane gas will be OK at a warm, humid RWV or STPR or NEFR, but will not be OK at cool, dry BRS or LSPR. |
darkknight9 Kirk Coughlin Elite Moderator Location: Saint Paul, MN Join Date: 01/08/2006 Age: Possibly Wise Posts: 493 Rally Car: Dreaming of escorts and xrats |
Heavenly god! How the hell is that even possible without Aliens acid for blood? Kirk Coughlin Woodbury, MN and River Falls, WI Quemadmodum gladius neminem occidit, occidentis telum est. |
Pretty easy...I have a set that looks more or less like that... 2 heat ranges too hot on the plugs, bad fuel feed and fuel rail set up because of the bizarre engine being half here and the other half somewhere way over there...pretty easy... But, being forged pistons they didn't shatter into 100 pieces so the crank and block is salvageable if somebody chose to salvage it... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
RWD4ME Morten Super Moderator Location: Vancouver Join Date: 08/28/2012 Age: Possibly Wise Posts: 88 |
Interesting thread, and I'm sorry that I'm seeing positive discourse from your unfortunate event!
Starion887 mentioned timing being too far advanced which took me back to high school. I was into Type 1 Beetles back then, swapping the OEM distributer with a Bosch 050 on a built motor was common place. Of course so was trying to get as much power as possible by advancing the timing. When the timing was advanced too far, the #3 piston suffered a meltdown. Now I can't rmember the reason but "seem" to remember that #3 was more affected than the others because it was the furthest away from the oil pump. I know zilch, zip, nadda, about Subie engines (yeah ok I used engine and motor for the same reference in one singular post, my bad) other than them being pancakes. That said, my high school failure in the Type 1 got me thinking about why the one particular piston in your case melted. Why that one and not the one beside it? Could lubrication (lack of) or cooling play a part in it's failure? Later in life (but still years ago) I raced stand up jet skis and organized events. Including one in Mr. Bottles backyard... on Spencer Spit on Lopez Island. The event was with the permission of Washington State Parks, which was difficult to obtain from a Canadian Company doing the event in the US. Launching from Anacortes with chase boats (graciously donated by ABC Yacht Charters in Anacortes) a large group of Jet Skiers crossed through Thatcher Pass to arrive for the event at Spencer Spit. Seems like eons ago... 1989! (But fuck was it fun!) Steve "Cosmic" Miller (The Man, The Myth, The Legend - as Splash jet ski magazine coined him in an article) had a Jet Ski performance shop just off the I-5 in Everett. He lived on Lake Stevens and tested all his builds there. I had 2, a Kawasaki X2 and a Kawasaki 650 SX. Standard bolt on mods, hi comp head, SS impellers, 44mm Mukini's, etc were common place. I got a little off topic, remeniscing (sorry about that!). Anyways Steve knew his shit, and there was no one North of California with his knowledge. Okay here's the point... When I had an engine failure and didn't have time to trailer my ski down to Everett I went to a local Kawasaki shop that did the rebuild. They messed up the air/fuel mixture and I melted a piston the first time out. Granted it's a 2 stroke and nothing like a fancy Subie, but is it remotely possible that air/fuel ratios could be a play in your failure? Presumably the ECU, the tune, etc have fail safes (again I know very little about these topics), but is it possible that there's somthing the system isn't able to diagnose? Sorry for going off topic slightly... Edited 1 time(s). Last edit at 01/17/2013 10:34AM by RWD4ME. |
