Got a chance to take the car out to CORE for a little bit of a shakedown on Sunday afternoon. Allison did most of the driving but I drove just long enough to get a feel for the transmission's characteristics to see if I wanted to continue down the path to getting the automatic to work.
Initial impressions were that it really wasn't all that bad. Flew up the road that cuts the property in half and got pretty close to topping out 3rd gear. Found the suspension a little on the soft side for my liking, but the front will get JVAB 40mm shocks as soon as John finishes the 50mm stuff. On loose surfaces coming into a hairpin, I'd just take the lever and bang it from 3rd to 1st. Gearbox would pull into 2nd just fine, but it would take a rear lockup or low speeds to get it to drop into first. The course was rough on the exit of a lot of the hairpins, so in an effort to preserve equipment, I wasn't trying to fly through them on exit.
Biggest area of concern is that after just one lap, 2nd gear started to just free-rev and if bumped up into 3rd it did the same. Let the revs fall back to idle and put it back in drive and it would get moving again. At first I would've chalked it up to the transmission just not being up to the task of dealing with the power the engine was making because it seemed to happen just as the engine was hitting its sweet spot (~4500rpms)...but it seemed to just do it in 2 distinct places on the track and once at a 3rd location. All three spots were places the car was leaning enough where the inside wheels were getting light. Could it be possible that sloshing in the transmission pan could starve it of oil? (I don't know enough about these things to know if that's a reasonable guess.)
It honestly felt eerily similar to when the rear diff stopped limiting slip on the white BMW, where the car would feel like it was chugging and revving in an uneven manner. However the difference was, once the car had leveled back out it continued to essentially free rev with a barely perceptible forward movement.
Thanks in advance for any thoughts!
