Buy, Sell & Trade
aquadave
David Bednar
Price Reduced: 1988 Mazda 323 GTX Rally Car - $5,000
September 10, 2012 12:10PM
Price reduced!
I've finally quit kidding myself that I have the time prioritized for this GTX, so it is for sale. It is located in Fayetteville, AR. I originally bought it from Dave Kern 4 years ago and have only driven it a handful of times on family/friend's farmland after I purchased it. It has been in garage storage and hasn't been started in the last year since the battery stopped turning it over. It was a hill climb car that competed in the Colorado Hill Climb Series, Pikes Peak, and Rally Idaho. My plan was to rally cross and then stage rally it.
Currently the car is set up to run normally aspirated, although it needs a jump/charge (probably new battery), tuning, and some minor fixes (rear quarter window install, solder in IAT sensor wire, radiator fan, etc. I have the turbo parts to set it up turbo again, it just needs some additional intercooler piping fabrication and mounting. The safety harnesses are out of date. The door bars and roof bar would need to be redone along with the addition of an a-pillar reinforcement bar to get a rally logbook. The GTX weighs 2600 lbs with the glass windows and both skid plates installed. It is a used rally car, it is not a show car.
Trailer can also be included, it was purchased from Dave Kern when I bought the GTX. It is a custom 16' steel trailer with two 3500lb axles, with trailer brakes on both axles. It has a tilting bed (with hydraulic hand pump, so no ramps are needed), it has a rail down each side (~30" wide) with a big opening in the middle, so when the car is on the trailer you have good access to the underside. Will include a Tekonsha Prodigy trailer brake controller as well.
1988 Mazda 323 GTX: (pictures on flickr)
Safety & Rally Gear and other stuff:
Roll cage by Salta Motorsports (1.75x0.095 main hoop, 1.50x0.120 other bars)
Momo Start seats
Sabelt 3" 6-point seatbelts
Custom skid plates
Front ¼" 6000 series skid plate – covers everything from the bumper to your feet
Middle 0.090" 6000 series skid plate – covers from your feet to the rear axle
Terratrip intercom
Roof vents (driver & co-driver)
Momo steering wheel and spacer
Back 5 windows tinted (CHCA requirement for glass)
Lightened front and rear bumpers
Odyssey PC680 battery mounted in trunk
Kill switch
2 fire bottles
Starter button
10" tall shifter stand with short throw shifter mod
5 gallon water tank for IC & radiator misters, and water injection
Three stage water mister setup (I-intercooler only, II top of radiator, III bottom of radiator) powered by at 40psi RV pump
Custom lightweight fiberglass hood with 2 GTR hood vents for radiator/exhaust manifold, and one large vent for the intercooler. Made with 2 layers of fiberglass and balsa core – very stiff.
Suspension, Brakes & Handling:
GAB Rally Struts (3f 3r some others with blown seals)
Eibach 12" springs, 150#, 200#, 250#
Mazdacomp rear LSD
No-front sway bar, stock rear bar
Escort/Galant front brake upgrade with long wheel studs
Miata/Galant rear brake upgrade with long wheel studs
Porterfield R4 brake pads ( one new set in box)
S10 front air dam
Motor & Accessories:
LINK standalone ECU
Knock sensor
air intake temperature sensor
electronic boost control
550cc RX-7 injectors
AEM wideband o2 sensor wired into ECU
Greddy memory boost & egt gauges
Greddy fuel pressure gauge
Bored out 1994 protégé 1.8L motor
9.0:1 Weisco Forged Pistons (1.88L final displacement)
GTR Forged Rods
Re-worked head from Corksport
Gasket matched porting
1mm oversized stainless intake & exhaust valves
Eibach high performance valve springs
GTR intake manifold
BPT exhaust manifold with garrett adapter plate welded on
Garrett GT2560R ball-bearing turbo
Spearco Intercooler and Evo 8 Intercooler (smaller top mount setup or large front mount setup)
Greddy Type-S blow-off valve (vented to atmosphere)
Walbro RX-7 Turbo fuel pump
GM coil packs (readily availabe at any autozone)
Magnecore 8mm plug wires (custom done from V8 domestic kits)
2.5" downpipe with divorced wastegate
2.5" test pipe, 2.5" high flow cat
2.5" cat-back exhaust
Two rear sections, one with muffler, one with high flow cat
Supra Twin Turbo fluidyne radiator
Fidanza 9lb flywheel with SPEC Kevlar clutch
Spares/Extras:
12 Stock GTX wheels with used rally tires in varying conditions
1 torn apart stock transmission
1 set of black doors with gutted interior and lexan windows
1 set of red doors with crank windows
1 spare rear hatch with lexan window
1 set of rear ¼ lexan windows
3 front bumpers (one with some minor damage, 2 with some stratches)
1 front bumper beam (un-touched)
1 spare rear bumper (some damage)
1 spare shifter cable
1 spare control arm
Trailing and lateral links (couple of each)
5mm, 8mm, and 10mm wheel spacers
Protégé N/A exhaust manifold & downpipe (in case you cant run a turbo car for your first few events)
Front axles
Mold for fiberglass hoods (ok for rally car, not ok for show car)
E-bay water injection setup (not hooked up)
I'm asking $6,000 $5,000 for the car and spares, or $8,000 $7,000 for the car, spares, and trailer.
Thanks,
David Bednar
(david bednar AT gmail DOT com)
870-243-ten seventy
Edited 2 time(s). Last edit at 09/19/2012 10:17PM by aquadave.
aquadave
David Bednar
Re: For Sale: 1988 Mazda 323 GTX Rally Car
Edited 1 time(s). Last edit at 09/10/2012 12:17PM by aquadave.
September 12, 2012 01:56PM
I hope for your sake you do not have to resort to parting this out. but i could use the GABS as well as a few other bits on my GT, Keep me in mind please.
aquadave
David Bednar
September 12, 2012 07:18PM
I am gaging interest in the car as a package. If it doesn't turn up anything in a few weeks, I will sell pieces off it individually. You are first in line for the GABs.
HiTempguy
2002 Subaru WRX STi
Re: Price Reduced: 1988 Mazda 323 GTX Rally Car - $5,000
September 24, 2012 10:18AM
Is the car driveable as it sits? Say, 2800kms?
I am seriously considering selling the 02' WRX I just picked up as a DD to purchase this car. If I am to write-off another car possibly driving like a dink, I'd rather it be an inexpensive one...
What year was the cage built?
aquadave
David Bednar
September 24, 2012 12:10PM
The car is drivable, as in on & off a trailer or around the block. But I would not consider a road trip with this car. It needs engine tuning to run well.
The cage was built in 2004.
Edited 1 time(s). Last edit at 09/24/2012 02:09PM by aquadave.
September 24, 2012 02:45PM
Cage was built in the fall of 2004 as I seem to remember some guys thrashing to get a VW re-prepped for that race while mine was in the shop.
It raced in CHCA in 2005, part of 2006 (was doing turbo kit upgrades that year and didn't get it all finished in time), and in 2007 it did the full CHCA calendar, Rally Idaho (the year it was all tarmac) and Pikes Peak (in 13:25).
September 25, 2012 09:02PM
Wait, something is wrong. Where is the tree sized dent in the side?
aquadave
David Bednar
September 25, 2012 09:37PM
The car has dents on it. Dents in rockers, roof, sides...its a rally car that has been belly up in its lifetime.
I dropped the price because I am trying to sell this sooner rather than later.
